7 members (Forty9, fonz8261, jkreiner, treegrower, Bill Hanlon, Wally / Montana, TexasJim50), 51 guests, and 0 robots.
Topics128,074
Posts1,055,914
Members48,429
#95166 03/21/2006 7:43 AM
Last night on the way to work I started my Apache and I let her warm up for about 15 min. in the driveway. I walked out and the motor was off. My neighbor said he heard a back-fire and the engine stopped. I looked at the spark wires all ok. the battery and starter all good,(the key was on) and I looked at the distr. no moisture in the housing
Rotor looks good but,I could not check for spark.
P.S. there is fuel,and the carb.is good. What am I forgetting?
Cliff(drove my 54 Plymouth to work)59
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
#95167 03/21/2006 2:04 PM
I
I Offline
It requires four things to run
1) fuel
2) compression
3) spark
4) the first three must be timed properly
Usually a backfire means something is out of time (firing with a valve open) or too richly fueled.
IRWIPI 2005 Peoples Choice
Inky,
"It's not that I haven't done IT... It's that I haven't done IT yet."
'48 1-1/2 ton Dump
'57 Chevy Panel
'59 Chevy 2 ton Dump
#95168 03/22/2006 4:36 AM
Thanks Inky I started with the points,condenser, and rotor but Now I will start looking at wires and plugs. tomorrow I will examine the timing.
Will return If I can't get her going in the AM.
regards
Cliff59
#95169 03/23/2006 9:44 AM
She works great now (needed new points)
thanks Inky
Cliff59
#95170 03/23/2006 1:30 PM
I
I Offline
Good for you! grin Glad you're back on the road! grin
Inky,
'48 1-1/2 ton Dump
'57 Chevy Panel
