| | | Forums66 Topics128,079 Posts1,056,296 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2013 Posts: 1 Moderated | | Moderated Joined: Jun 2013 Posts: 1 | I have a 54 Chevy Belaire in France. My problem is my leaking rear main bearing seal.(split seal). I was told there are no seals available and that I must use a newer seal from 55-62 engine which is a different size. The crankshaft must be machined down to fit the newer seal. My question is what size do I cut the crankshaft to fit the newer seal? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Don't listen to who ever told you that. 1940-62 used the same seal. 1956-62 engines can have the rope seal replaced with a two piece neoprene seal. There is a one piece seal conversion but that takes machining the block. I would recommend using a Best Gasket brand rope seal for your 54.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2012 Posts: 135 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 135 | | | | | | Joined: Jul 2013 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 45 | Like to jump in here. Are these rear main seals available at NAPA, or where should I look for one. I assume there is a front seal also. I have a 54 235 that is leaking, I think it the pan gasket, but thought I may as well replace the rear main seal. How tuff is this?
awk | | | | | Joined: Jul 2013 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 45 | Pre'68 Dave, Thanks. So that yellow thing is a tool? The front should be easy that just the timing cover seal, right. I'm new to the 235 6 cyl.
awk | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The yellow thing is a razor knife and the brown thing is a guide for cutting the ends correctly. The only thing the kit tells you to do that I don't is to drill the cap and pin it so the seal does not move. I don't like that idea. The front seal leak could be more from a worn seal surface on the balancer. They sell a speedi-sleeve to cover the worn area. It is the same as small blocks so most parts stores have them in stock. The front seal is a standard lip seal. I see a lot of leaking blamed on front seals when it turns out to be the fuel pump. There are two places fuel pumps leak. They can leak from a loose pivot shaft or more commonly someone used lock washers on the bolts. The oil then wicks out the threads and through the split in the washer. This can leak a lot of oil.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2013 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 45 | Thanks a bunch Dave. I'll look at that tonight. | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | dave do you recommend NOT using lock washers on the fuel pump? without them might they protrude into the block far enough to hit a cam lobe?
rolf
1963 c10 | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Being the pump is aluminum I always use flat washers to keep the bolt heads from digging in.
