| | | Forums66 Topics128,026 Posts1,055,404 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 85 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 85 | I've been tunning up my 1953...235 engine. Should I be able to see the distributor turn (vacuum advance) when I rev the engine?
I've tried it and it doesn't appear to move. Yet it runs and start great. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | The vacuum control further advances your timing at high vacuum situations. It was mainly designed for a little more fuel economy. Most larger trucks had no vacuum control because they were at full throttle most of the time. The chances are good that you have a ruptured diaphragm or the linkage is hanging. When my jalopies are running good, I leave them alone. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | The vacuum advance moves the internal parts of the distributor, the outside doesn't move. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The vacuum advance moves the internal parts of the distributor, the outside doesn't move. ??? The vacuum advance unit on a 216/235/261 is attached to the outside of the distributor - you can see the distributor move. The mechanical advance mechanism (weights/springs) are inside the distributor and you cannot see them at work. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you disconnect the vacuum line, rotate the distributor and put your finger on the hole, the unit should stay turned. | | |
