0 members (), 61 guests, and 4 robots.
Topics128,024
Posts1,055,395
Members48,422
#951493 06/20/2013 2:02 AM
I've been tunning up my 1953...235 engine. Should I be able to see the distributor turn (vacuum advance) when I rev the engine?
I've tried it and it doesn't appear to move. Yet it runs and start great.
DJRoy #951494 06/20/2013 2:20 AM
The vacuum control further advances your timing at high vacuum situations. It was mainly designed for a little more fuel economy. Most larger trucks had no vacuum control because they were at full throttle most of the time. The chances are good that you have a ruptured diaphragm or the linkage is hanging. When my jalopies are running good, I leave them alone.
DJRoy #951536 06/20/2013 10:10 AM
The vacuum advance moves the internal parts of the distributor, the outside doesn't move.
Jim Sears #951538 06/20/2013 10:20 AM
The vacuum advance unit on a 216/235/261 is attached to the outside of the distributor - you can see the distributor move. The mechanical advance mechanism (weights/springs) are inside the distributor and you cannot see them at work.
DJRoy #951603 06/20/2013 5:22 PM
If you disconnect the vacuum line, rotate the distributor and put your finger on the hole, the unit should stay turned.
1951 1 Ton Completed
