3 members (klhansen, dt235sd, 1 invisible), 67 guests, and 0 robots.
Topics128,049
Posts1,055,679
#95133 03/18/2006 12:54 AM
8
8 Offline
Ok. I have a 1941 Chevrolet 1/2 ton pickup. I have replaced the battery. Rebuilt the Generator and the Starter. I have checked and cleaned every connection. I have new battery cables installed.
Despite this if the truck sits for a day without running then she won't start without charging up the battery. Now let me say that this is my third battery. The last one I choose is the Allstate Battery. It is rated No. 1 in cranking power. I just don't know what keeps draining the battery.
Now I just disconnect it after driving and reconnect it when I want to go. While this is a lot of fun I would rather not pull the floor and charge the battery. Any ideas?
Greater love have no man than this,
That he let his wife drive his truck to the grocery store.
Start by removing one battery cable and placing an amp meter between the cable end and the battery post. With the truck turned off you should have zero amps, if you don't have zero amps then something is drawing current from the battery. To find out what the culprit is you can narrow it down by removing fuses one at a time and then checking the amp meter to see if it goes to zero. Once you have narrowed down the fuse then you will have to check each device ( lamp light horn ..whatever) that is on that fuse one at a time until the amp meter reads zero. If removing fuses does not cause the amp meter to zero then you have either an un-fused device that is causing the current draw.
1947 Chevrolet "under construction"
Is it charging?
If it is, then start pulling cables and fuses.
If it's not, check the polarization on your generator or make sure the regulator is working right.
Check out the tech tip on generators here
If polarizing the generator doesn't do it,I'd replace the regulator-in fact,I'd replace it anyway,just for good measure.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
8
8 Offline
Thank you my friends. I'll let you know the outcome.
you can also just use a test light between the batt and cable when lite goes out drain found...doc
8
8 Offline
OK new regulator installed. To review new starter, regulator, generator, battery cables. I have used a amp meter and it does show a slight discharge. It's coming from the heat & defroster switch. With the starting switch in the off position I used a test light on the heat & defrost switches. They both show HOT. This shoudn't be hot, should it? I believe that someone wired the switches to be hot all the time. Qusetion. Where should they be wired to? Thanks Again.
you might consider a quick disconnect switch, I installed one after not being able to find a drain that usually took about 5 days,, I just reach down and flip when I start and when I park it at night I just flipp it off, mine is installed on the inside fire wall..........it would be best to find the source, now I dont even worry about it. works for me........Fred
Redryder pix
My Hotrod
If both show hot then that means voltage is flowing to your haeter motor at all times maybe a bad heater switch. disconnet both wires going to the switch and test again only one should have voltage on it.
8thairforce,... I have a stock 6volt 41 pickup. all original. And I have a hot heater blower motor too. Found out when I left it on one night. Sounds like you found your culprit, the switch. I don't have the diagram here, but I think it's hot all the time. Mine is the three position switch, brown bakelite. up is off, then low and high.
1941 AK named "PETEY" my buddy.
My heater switch is hot all the time, as well. There was just too much amperage running to those old heaters to run the wiring through the ignition keyswitch, so they just wired everything with large draws directly to the back of the ammeter.
I second (third?) the notion of replacing the switch.
If you're really concerned about it being hot all the time, you can do as Joker does and put a battery cut off in, or you can just put in a toggle switch in between the heater switch and the ammeter. If you take the second route, make sure to get a switch that is beefy enough to handle that amperage.
I had the same problem with my 54-GMC, couldn't find the source of the drain. I replaced just about every cable and wire and cleaned every connection. For some reason I decided to replace the headlamp switch. No problem since.
kdrown, are you speaking of the cab dome light or the head light switch ?
thanks,
Redryder pix
My Hotrod
SEE INLINERS SITE
Nothing can be more frustrating or confusing than trying to find a short in you car's electrical system. Especially when it's not enough to blow a fuse but still drains your battery! Obviously, if you find a blown fuse, replace it, turn the key on, and the fuse blows immediately you've found the circuit within your car's electrical system that the short is in. However, if the draw does not create enough current to blow a fuse, than we have to find out which circuit it's in to fix it. Before I get started, my intention in this Tech Tip is not to teach Electrical Systems and Electronics. Instead, I just hope that this article will give anybody a systematic approach to finding a short. So lets get started... First, lets make sure that you have a short! Electrical systems have a specific route for electricity to travel along and any change from this route causes problems. If electricity can find an easier route it will always take it. So lets find out if the electricity in your car is finding a ground sooner than it's suppose to... What we're going to do is take a test light and attach the clip end to the negative battery cable and put the tip on the negative battery post. Then we're going to remove the
negative battery cable making sure we don't touch the test light. Now we haven't broken the electrical connection here. All we're doing is letting the current, if any, flow out of the negative battery post, through our test light to see if it illuminates, and continue on along the negative battery cable to the short. Word of caution, If you're attempting this on a computer controlled car it is very important not to break the connection of the test light to the negative battery post.
By not breaking the connection, the computer will maintain its learned driving strategy in the Keep Alive Memory (KAM). It will also ensure your computer will not have to go to factory baseline and relearn controlling your car's engine for maximum fuel economy and performance. While we're on the subjects of computer control, module equipped cars have a small parasitic drain caused by the modules' KAM. This is normal and module or modules can draw 10-21 milliamps (mA) with the key off. However...
If you have a parasitic draw that is in the milliamp range and is beyond normal specs, you will have to use an Amp Probe for a Digital Volt Ohm Meter (DVOM) to diagnose this and the method below may not work due to the very low current draw. But let's get back to those major shorts that give us all those headaches...
Oh! by the way, a DVOM can be used in place of a test light. Just ensure your leads are in the proper connections to measure Amps. Using this tool will not only tell you if you have a current draw when you're not suppose to, but will also tell you how many Amps are being drawn.
Okay, you've confirmed you have a short, now how do you find it? The first and easiest test is disconnect the alternator and see if the test light goes out or the DVOM display changes. Often old or worn out alternators ground themselves internally causing a short. If it does you've found your short and repair or replace the the alternator or appropiate components. If the test light remains lit or the amperage on the DVOM does not change, you have to try and start isolating which circuit within your car's wiring has the short. This can be done by pulling fuses one at a time. A fuse is nothing more than system protection. All the current that flows through a circuit must go through the fuse. By pulling a fuse we've created an open and current can no longer flow. Continue doing this until the light goes out or the DVOM display changes showing no current draw. Once you've found the circuit that has the short you must find where in that circuit the short is located. It's always best to take the least intrusive method to diagnose. Besides, who wants to tear out the dash or remove the interior just to trace a wire. So this is where a simple tool you can make comes in very handy...
When electricity flows through a wire it creates magnetism. We're going to use this magnetism to find our short! Many tool vendors and auto parts stores sell short detectors. The one in my tool box is from MAC. It's convenient for me because it also has an audible alarm which I can hear in a noisy shop environment. I'm pretty sure NAPA sells one also. The tool to the right consists of a 10 Amp circuit breaker with buzzer, wire leads, clips, and a compass. But for our purposes we're going to make our own which I believe is better than the ones you can buy outright.
To make our short detector, we'll need the following items:
1 x 20 Amp circuit breaker
2 x alligator clips
2 x spade connectors
2 x 2 foot pieces of 18ga wire
4 x 1 foot pieces of 18ga wire
1 x magnetic compass of any type
*modify length of wires to meet your needs*
MAC's ET251 SHORT CIRCUIT FINDER. Quickly locates short circuits in all 12v automotive electrical systems. Eliminates the need to remove upholstery and floor coverings. Operates through metal posts, panels, and other obstructions. Simple hooking to affected fuse posts; induction-type needle indicator pinpoints shorts. Packaged in high impact plastic box; schematic included
(Not To Scale)
Connect the pieces together as shown. This should allow you to hook your tool up in place of a fuse no matter what type of fuses your car uses. The reason I recommend a 20 Amp circuit breaker instead of a 10 Amp one is it allows current to flow longer and thus building more magnetism. This is important especially if the wire that the short is in is buried under items like the carpet, rocker cover, door panel, pillars, etc. The more magnetism we can build the easier it will be to pick it up with our compass.
At this point it helps to know how the wiring loom or wires run for the circuit that has the short. A schematic is very helpful here especially if it has component locations. If you cannot find one or your vehicle is older you will have to trace the wire(s) from the fuse on...but this is not that hard and you'll see why. The reason we want to know which way the wire is going from the fuse box is because we're going to use the magnetism that is built buy the electricity along that wire to locate the short. Place your tool into your fuse box or where you pulled the burnt fuse from instead of the fuse and turn the key on to the RUN position. Now what's going to happen is electricity is going to flow to the short. Because we have a circuit breaker in there instead of a fuse we're allowing magnetism to build along the wire. As the current flows through the circuit breaker it starts to heat up (careful the tool may get very hot). The bi-metal strip inside the circuit breaker will eventually bend away from the contact breaking the circuit and creating and open before any damage can be done. This is always associated with an audible "CLICK" from the circuit breaker. With an open, no current can flow through the circuit breaker and the shorted circuit. With no current flowing, the bi-metal strips cools very quickly and reforms itself back to it's original shape and touches the contact allowing current to flow and once again creating magnetism.
We're going to use this magnetism and our compass to locate the short. Here is how the this works... A wire (conductor) will build magnetism. A short will not. So we put our compass along the wire or wire loom and the current flowing through the wire is building magnetism. This magnetism will draw the north seeking arrow on the compass towards it (one way or another). We leave our compass in place until we hear the "CLICK" from the circuit breaker. When the circuit breaker opens the magnetism will be lost and the north seeking arrow of the compass will deflect back towards the magnetic pole of the earth momentarily. This deflection is important! Because once we get to our short there will be very little or no deflection at all. So after each click and deflection we move the compass about 6-12 inches along the wire, wait, and watch for the needle to deflect as the circuit breaker opens and closes. We continue doing this until we come to a portion of the wire where the needle is not being drawn towards the wire (weak or no magnetism) and there's no deflection of the compass needle when the circuit breaker opens. Congratulations! you've found the area where the short is located. However, you still have not found the short, but at least you know where to dig in. Expose that portion of the wire and locate the short in the wire. Here's a hint - if there's a bunch of wires there, shorts create heat. So look for the hot wire, hot metal, or hot component. Then look for any wire or component that may be broken, cracked, smashed, exposed, or punctured.
Now that you've found the short, repair it by splicing in a new piece of wire, fixing, or replacing the shorted component. You can cut & solder, use a butt contector, or electrical tape if you have nothing else. At one time automobile manufactures only recommend solder, however, the quality of butt connectors are so good today that many allow this type of repair. Now that you have the short out of your system verify your repair, replace the fuse if necessary, and pat yourself on the back for a job well done.
That's all there's to it folks. Go for it!
Jim & Caroline
