1 members (baldeagle),
48
0
Mod | | | Forums66 Topics128,003 Posts1,055,244 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95120 03/15/2006 11:35 PM | Joined: Jan 2006 Posts: 33 Junior Member | | Junior Member Joined: Jan 2006 Posts: 33 | I have a 66 C20 with four speed. The previous owner didn't think it needed the reverse light switch.....any idea what it is supposed to look like and where/how it mounts? All the wiring is there, and to the lights, just no switch and connector. Thanks, Josh | | |
#95121 03/16/2006 5:07 AM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | If you have the granny box (SM420) 4 speed you ain't go one. The only 420 with a reverse switch was in the 67 trucks. Larry
I don't own a vehicle that isn't old enough to drink. | | |
#95122 03/17/2006 7:08 AM | Joined: Jan 2006 Posts: 33 Junior Member | | Junior Member Joined: Jan 2006 Posts: 33 | In 67, where did they put the reverse switch? I also wonder if I could install one? When I got the truck, it had the cutouts in the back for the lights, and a wire from the harness to each empty hole, and this funny little tab at the base of the stick shifter just inside the cab with a green wire sticking up through it. So I figured it used to have one that the previous owner removed along with the tail lights. I have the lights in and the wiring in place up to the tranny....just need the switch | | |
#95123 03/18/2006 3:55 PM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I had a 1966 c-20 custom camper that had a original granny 4-speed with reverse lights. I remember the green wire that cowinfog is talking about.My switch went bad, and i could not find a replacement.I know it kind of looked like an oversized glove box light switch.I sold the truck,when gathering all the parts that went with it, i did not find it.You may want to try to get a hold of lilred66 and see if he has one.He is very knowledgable about the 64-66 trucks,possibly may have what you want. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#95124 03/19/2006 9:17 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I put backup lights in my 54 ... I dunno if it's what you're interested in, but here's what I did and how: Click Here
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#95125 03/22/2006 4:05 PM | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | LGriffin: I must correct you on the factory reverse lights avialable on the '66 C10, C20, K10 & K20 with the factory equipped SM420 four-speed on the floor manual transmission. The reverse lights became available in 1966 on these models. Attached is a picture of what the assembly looks like. \'66 Chevy Truck Reverse Light Assembly I hope this information is helpful and clears up the availability issue of reverse lights as a factory/dealer option in 1966. bowtietim, thanks for the nod. | | |
#95126 03/23/2006 2:58 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Yep, that is the one i remember.It was a factory option on my c-20 kustom camper.Great pictures tony !! 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#95127 03/23/2006 1:55 PM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | 4-5-6 Chevy Trucks, Is this type of reverse light switch available by any vendors? It looks like this type of switch could be adapted to most trucks with SM420's. Thanks.
Jim
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
#95128 03/27/2006 8:37 PM | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Jim Thats exactly what it is on a 66 sm420 Backup lites were only an option beginning that year If i,m not mistaken 67 sm420 top cover was the 1st one drilled for a reverse switch Also there was a thread awhile back about this very thing,And someone posted a link to how to drill and tap an older 420 tower for a pushbutton switch Regards | | |
#95129 03/28/2006 1:08 PM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | Steve, According to my SM420's date code it should be a 1967, but mine does not have a reverse switch installed in the cover. I will have to look for the thread on this subject, it would be nice to have reverse lights on my truck.
Jim
#95130 03/28/2006 1:24 PM | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Jim As I remember Your ride was a put together from a previous Auto trans truck so youre trans could be a 67 case with an earlier Shifttower on it Damnit if I could only find that link,it wasnt that difficult to do.......... | | |
