2 members (Gdads51, Jon G),
147
0
Mod | | | Forums66 Topics128,198 Posts1,057,272 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2013 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 36 | Hi everyone. I'm new in all aspects to the Stovebolt world. Just bought a fairly rough but operational 61' Apache C-10 and just located and registered on this forum. Been cruising the internet since I brought the girl home and it looks like this is the place to be. I want to install dual exhaust and dual carb intakes. Searching around, it appears to me that Tom Langdon would be the place to go for one stop shopping.I'm not a mechanic but am fairly mechanical. I know this topic has been thrown around a bunch. I just want to make the upgrade as painless and productive as possible.Are there other suppliers other than Langdon's that will assist me in getting the right combinations to help the 235 breathe better? Oh yeah, and sound and look cool. Thanks, Mike | | | | | Joined: Mar 2000 Posts: 1,184 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,184 | Patricks Antique CarsPatricks sells Fenton intakes and headers as well as dressup parts. They're good people to deal with. Very knowledgeable and won't let you make a mistake buying something that won't work for your setup. (No, I don't have any financial interest - I'm a happy customer. I bought an Isky cam and lifters from them.) | | | | | Joined: Jun 2013 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 36 | Thanks. I'll give Patricks a look. Just want to do it right the first time. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Mothertrucker in AZ sells the Fenton headers at a good price.
The Fenton dual-intake works without modifications with the Fenton headers. You will have to heat the intake manifold. I use hot air with the Fenton intake (no matter what Langdon says) or hot-water with the Offenhauser intake (that intake, and the Clifford intake, if still available, have a side-to-side flow-through internal heat-chamber).
Patrick's is a good source for any parts, if he has them in stock (he will usually dicker on price).
Langdon's dual Carter-Weber carburetors are well-matched to a 235. Get his linkage kit, if you get those carbs.
One readily available (and relatively inexpensive) higher-lift cam would be a 261 cam (this was also used in 235 Corvette engines).
The stock mufflers are civilized-quiet and are a baffled straight-through design. I doubt if the back-pressure is different from other, louder mufflers. The dual exhaust is a must for higher performance with dual carbs (or, with a bigger, single carb).
| | | | | Joined: Jun 2013 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 36 | Thanks for all the info guys. I have heard good things about the Carter Weber set up for the 235 from Langdons. I don't see an intake manifold in his catalog though. How about the Williams headers? I don't hear anybody mentioning them. All I hear is Fenton. | | | | | Joined: Apr 2013 Posts: 14 New Guy | | New Guy Joined: Apr 2013 Posts: 14 | Tom has told me that they fit the Offenhauser intake, which you would need to buy from a different vendor. | | | | | Joined: Feb 2002 Posts: 2,896 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,896 | http://www.inliners.orgis another great site to learn about inline engines. -W | | |
