1 members (NJC),
47
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95075 03/15/2006 12:03 PM | Joined: Dec 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 92 | 12 Volt to 6 Volt voltage reducer for gauges Is this the the right resistor 60 ohm 2 watt for such as fuel (gas) gauge, water temperature or oil pressure. Or go for the Runtz 12v to 6v voltage Thanks Maxx
52 GMC Grumman Olson Kurb Side stepvan T3-8(Comet)69 GMC 1/2-ton
#95076 03/15/2006 5:22 PM | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | the experts on here will tell you that there is a difference in a "reducer" and a "resister". a lot of info on here about this switch (6 -12) in the search area but i believe you want the Runtz or a similar product.
54 3100 w/62 235 "Yosemite Sam" Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
#95077 03/15/2006 7:55 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | maxx - the 2watt resistor will work for your gas gauge which uses very little current - the water and oil gauges are not electric - heavier duty voltage droppers needed for things like heater fan and radio
Bill | | |
#95078 03/21/2006 2:41 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Maxx, if you want to run a 6 V gas gauge on 12v, use a 30 ohm 2 watt resistor. The gauge uses around .2 amps and that works out to 1.2 watts on the resistor. | | |
#95079 03/29/2006 4:58 PM | Joined: Jan 2000 Posts: 124 Shop Shark | | Shop Shark Joined: Jan 2000 Posts: 124 | You need the Runtz because it is a solid state voltage reducer...not a resistor. Because the dash gauge...your fuel gauge for example runs on just a quarter of an amp and a resistors trypically have a 40 percent varation in voltage depending on the electrical load that is a lot to a gauge that runs on just a quarteer of an amp. By contrast a Runtz is a solid state device that puts out te correct voltage regardless of the electrical load. Thanks Randy | | |
