2 members (NJC, baldeagle), 57 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#95075 03/15/2006 12:03 PM
12 Volt to 6 Volt voltage reducer for gauges Is this the the right resistor 60 ohm 2 watt for such as fuel (gas) gauge, water temperature or oil pressure.
Or go for the Runtz 12v to 6v voltage
Thanks Maxx
52 GMC Grumman Olson Kurb Side stepvan T3-8(Comet)69 GMC 1/2-ton
#95076 03/15/2006 5:22 PM
the experts on here will tell you that there is a difference in a "reducer" and a "resister". a lot of info on here about this switch (6 -12) in the search area but i believe you want the Runtz or a similar product.
54 3100 w/62 235 "Yosemite Sam"
Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
#95077 03/15/2006 7:55 PM
maxx - the 2watt resistor will work for your gas gauge which uses very little current - the water and oil gauges are not electric - heavier duty voltage droppers needed for things like heater fan and radio
#95078 03/21/2006 2:41 AM
Maxx,
if you want to run a 6 V gas gauge on 12v, use a 30 ohm 2 watt resistor. The gauge uses around .2 amps and that works out to 1.2 watts on the resistor.
1951 1 Ton Completed
#95079 03/29/2006 4:58 PM
You need the Runtz because it is a solid state voltage reducer...not a resistor. Because the dash gauge...your fuel gauge for example runs on just a quarter of an amp and a resistors trypically have a 40 percent
varation in voltage depending on the electrical load that is a lot to a gauge that runs on just a quarteer of an amp. By contrast a Runtz is a solid state device that puts out te correct voltage regardless of the electrical load. Thanks Randy
