1 members (JW51), 137 guests, and 2 robots.
Topics128,049
Posts1,055,741
#95069 03/14/2006 7:23 PM
Junior Member
Junior Member
Hi, I know this most likely isn't a new problem but, for me it is. I just got all the rest of my wiring in order from the previous hack job, and when I checked my turn signals, they all worked except when I turned on the left turn signal, both front lights flashed dimly and while all the rest flashed brightly when they were supposed to. SOOOOO this is isolated to the front turn signals, both flashing dimly when I set the signal to flash for a left turn. It's a 66 C20. Thanks, Josh
#95070 03/14/2006 9:12 PM
That sounds like a grounding problem.
Make sure the sockets are grounding right. Does a '66 have the turn signal lights in the hood still? You might try running a temporary jumper wire from the light socket to the negative post of the battery to see if that clears the problem. If it does the problem is definately a bad ground.
#95071 03/14/2006 9:43 PM
Junior Member
Junior Member
Yes, it still has the turn signals in the hood. The voltage is definitely being shared betweenthe two lights, because the right side is bright, while the left causes both to light up dimly.
#95072 03/14/2006 11:43 PM
Riding in the Passing Lane
Check the ground at the lights & put a ground wire from the hood to the firewall.
1972 Chevy c10 Cheyenne Super
#95073 03/16/2006 10:59 AM
I'll bet it's a bad ground for the left front light housing.If the hood wasn't grounding both directions would be feeding back.It's still good to run a ground wore to the hood though. I used an old battery cable for mine,it was just the right length and already had the lugs on it. I just pulled one mounting bolt from the top of the hinge and one from the bottom,wire-brushed the surfaces and the facing and threads of the bolts off really good,and bolted it up.
The same basic idea applies for any grounding problem.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#95074 03/16/2006 12:56 PM
I too would say a bad ground on the left light. What happens is the current meant for the left turn signal element also travels through the left parking light bulb which in turn goes across the parallel connection to the right parking light bulb and then to ground. If you happened to remove the right bulb, the left front wouldn't work at all.
1951 1 Ton Completed
