| | | Forums66 Topics128,047 Posts1,055,532 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95069 03/14/2006 7:23 PM | Joined: Jan 2006 Posts: 33 Junior Member | | Junior Member Joined: Jan 2006 Posts: 33 | Hi, I know this most likely isn't a new problem but, for me it is. I just got all the rest of my wiring in order from the previous hack job, and when I checked my turn signals, they all worked except when I turned on the left turn signal, both front lights flashed dimly and while all the rest flashed brightly when they were supposed to. SOOOOO this is isolated to the front turn signals, both flashing dimly when I set the signal to flash for a left turn. It's a 66 C20. Thanks, Josh | | |
#95070 03/14/2006 9:12 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | That sounds like a grounding problem.
Make sure the sockets are grounding right. Does a '66 have the turn signal lights in the hood still? You might try running a temporary jumper wire from the light socket to the negative post of the battery to see if that clears the problem. If it does the problem is definately a bad ground.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#95071 03/14/2006 9:43 PM | Joined: Jan 2006 Posts: 33 Junior Member | | Junior Member Joined: Jan 2006 Posts: 33 | Yes, it still has the turn signals in the hood. The voltage is definitely being shared betweenthe two lights, because the right side is bright, while the left causes both to light up dimly. | | |
#95072 03/14/2006 11:43 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Check the ground at the lights & put a ground wire from the hood to the firewall. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#95073 03/16/2006 10:59 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | I'll bet it's a bad ground for the left front light housing.If the hood wasn't grounding both directions would be feeding back.It's still good to run a ground wore to the hood though. I used an old battery cable for mine,it was just the right length and already had the lugs on it. I just pulled one mounting bolt from the top of the hinge and one from the bottom,wire-brushed the surfaces and the facing and threads of the bolts off really good,and bolted it up. The same basic idea applies for any grounding problem. Speed | | |
#95074 03/16/2006 12:56 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I too would say a bad ground on the left light. What happens is the current meant for the left turn signal element also travels through the left parking light bulb which in turn goes across the parallel connection to the right parking light bulb and then to ground. If you happened to remove the right bulb, the left front wouldn't work at all. | | |
