2 members (Peggy M, Jon G),
51
Mod | | | Forums66 Topics128,009 Posts1,055,296 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95014 03/10/2006 4:15 AM | Joined: Nov 2005 Posts: 266 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 266 | I just replaced one of my taillights on my '66 C-10 stepside. It works fine except that when the brakes are on and the turn signal is on, it won't blink from high to low, instead it blinks on and off. Also, when the headlights are on and I press the brake pedal, it cuts off, and when the headlights are on and the turn signal is on, it blinks on and off, not high to low like the old one did. What's going on with it and what can I do to fix it? Any help is much appreciated.
Drew -------------------- '66 C-10 stepside | | |
#95015 03/10/2006 4:51 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the normal condition is NOT "high to low" - the tail lights are the dimmer of 2 lights, the brake is the brighter, when the blinker is on, the brake light is what blinks, the tail light just can't be seen because the brake/blink light is so bright
when the tail lights are on both sides should be the same brightness, when you hit the brakes, bith light should appear to get brighter as the 2nd element comes on, the blinker just interrupts the brake signal to whichever side is selected - anything else means you've got it wired wrong or are missing a ground
sounds to me like you've got the wires reversed, or both the tail and brake/turn wires both to the same terminal, or the brake/turn wire is hooked to the wrong side of the socket and the tail light wire just isn't hooked up
Bill | | |
#95016 03/10/2006 10:46 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You may have a bad ground on the respective light. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
