3 members (Hotrod Lincoln, mick53, 1955 1 Series), 33 guests, and 6 robots.
Topics128,012
Posts1,055,312
Members48,419
#95014 03/10/2006 4:15 AM
I just replaced one of my taillights on my '66 C-10 stepside. It works fine except that when the brakes are on and the turn signal is on, it won't blink from high to low, instead it blinks on and off. Also, when the headlights are on and I press the brake pedal, it cuts off, and when the headlights are on and the turn signal is on, it blinks on and off, not high to low like the old one did. What's going on with it and what can I do to fix it? Any help is much appreciated.
Drew
'66 C-10 stepside
#95015 03/10/2006 4:51 AM
the normal condition is NOT "high to low" - the tail lights are the dimmer of 2 lights, the brake is the brighter, when the blinker is on, the brake light is what blinks, the tail light just can't be seen because the brake/blink light is so bright
when the tail lights are on both sides should be the same brightness, when you hit the brakes, bith light should appear to get brighter as the 2nd element comes on, the blinker just interrupts the brake signal to whichever side is selected - anything else means you've got it wired wrong or are missing a ground
sounds to me like you've got the wires reversed, or both the tail and brake/turn wires both to the same terminal, or the brake/turn wire is hooked to the wrong side of the socket and the tail light wire just isn't hooked up
#95016 03/10/2006 10:46 PM
Riding in the Passing Lane
You may have a bad ground on the respective light.
1972 Chevy c10 Cheyenne Super
