4 members (JW51, rfs56trk, Cosmo, 1 invisible),
119
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 52 | I am in the process of installing new tie rod ends, Pittman arm and Idler arm in my 1965 C-10. I can't find any specification on what these items are to be torqued. Does anyone know what the torque specs are for tie rods ends, Pittman arm and Idler arm? | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I have that info at home. I did mine last fall, so I'm sure I can find it. More later. | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I found my notes. Pitman arm to Center Link = 45+ I wrote down steering arm, ball joint and shock torque specs, but I don't have the Idler arm info. Very sorry. I think my new Tie Rods came with paperwork that gave the torque specs.
Well, I did at least have the Pitman arm spec. Sorry I couldn't help more.
Jay | | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | OK, just trying to finish up a front-end on a 66 GMC.
I couldn't find anything in the GMC manual on tie-rod ends. I ended up with 40 ft.lbs, but that was a guess. The manual does not bother with torque settings for all fasteners, seems to be hit or miss. In the specfications they list out sized and dimensions as if you might just mill your own stuff. :-)
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Regie, in those cases I usually just go from experience and the "feel". (And I know you have experience)! Does the 66 have the hole for a carter-key? If so I know you'll do it right and put big one in there!!! | | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | Yep, Chipmunk. All the suspension and steering was castle nuts and cotter pins, except the upper balljoints to A arm that went from original rivets to grade 8 bolts and nuts with lock washers or jetnuts. Well, shocks were plain bolts...as were Ubolts holding lower A arms to crossmember.
Bolts from spindles to steering arms were 1/2 inch grade 8 with a long shoulder. Went to Fastenal and got close replacements should have waited overnight for McMaster-Carr. Replacement Moog stuff was hecho in china and not as good as original stuff.
R-Bo
