2 members (Charles in CA, Ponchogl), 83 guests, and 1 robot.
Topics128,131
Posts1,056,722
Members48,454
8
8 Offline
Has anyone converted the 3/4 ton tie rod ends to the standard (replaceable) tie rod ends? Specifically from the same year 1 ton. I read a tech tip online that you could press out the old stock tie rod end balls and use 1 ton (3800) tie rod ends in there place. I have yet to try it and am not convinced that it will work. Any experience?
Thanks.
Here's what I did. I would think your 56 would be the same.
3/4 tie rod end swap
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
8
8 Offline
Thank you.
This is exactly what I found, the ES150R and ES150L that is.
And just like you they were mislabeled, although the boxes read both L and R. I got two Left hand thread tie rod ends. I'm gonna have to source one locally instead of ordering on-line.
I picked up some 1"IDx.120 wall DOM tubing and 3/4x16" threaded tubing inserts with jam nuts to complete the package.
I'll post pics when it's complete.
