| | | Forums66 Topics128,094 Posts1,056,483 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2013 Posts: 27 New Guy | | New Guy Joined: May 2013 Posts: 27 | Has anyone converted the 3/4 ton tie rod ends to the standard (replaceable) tie rod ends? Specifically from the same year 1 ton. I read a tech tip online that you could press out the old stock tie rod end balls and use 1 ton (3800) tie rod ends in there place. I have yet to try it and am not convinced that it will work. Any experience?
Thanks. | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Here's what I did. I would think your 56 would be the same. 3/4 tie rod end swap
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: May 2013 Posts: 27 New Guy | | New Guy Joined: May 2013 Posts: 27 | Thank you.
This is exactly what I found, the ES150R and ES150L that is.
And just like you they were mislabeled, although the boxes read both L and R. I got two Left hand thread tie rod ends. I'm gonna have to source one locally instead of ordering on-line.
I picked up some 1"IDx.120 wall DOM tubing and 3/4x16" threaded tubing inserts with jam nuts to complete the package.
I'll post pics when it's complete. | | |
