0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
#94964 03/07/2006 6:24 PM
Junior Member
Junior Member
When I rewired my '49 1 ton, I removed what looked like an accessory voltage reducer from the post on the ammeter that was lowest; closest to the ground. It was poorly wired so I didn't put it back. This truck was changed to 12v in the 1960's. I replaced the 12v gen with an Alt.
Everything works fine, but is this voltage reducer a necessary application for the original 6v ammeter? (or was it a fix done by someone in the past for some other problem?)
And, would it also be suggested to install an in line voltage reducer for the original gas gauge?
thanks
Frank
1949 Chevy 3800
1929 Chevy International
Amps are amps. The ammeter doesn't care about volts. I'm not sure why there would be a voltage reducer off of the ammeter unless it was the line that went to the fuel gauge.
The fuel gauge should have one, and if it doesn't you may have fried it.
Junior Member
Junior Member
Luckily the fuel gage is the only thing I haven't hooked up yet.
Frank
1949 Chevy 3800
Ex Hall Monitor
Ex Hall Monitor
I had a 55 1st panel that I converted to 12v. All the gauges ran at 12 volts without a voltage reducer. I put over 100K on the truck after the conversion and never had a problem with the gauges.
Yep, you'll need it on the fuel gauge. I fried one and was lucky to find another in the bone yard!
~ Kimberly
My '54 ... and my '63 and a '59 F100
#94969 03/09/2006 12:14 AM
Riding in the Passing Lane
Don,t use just any resister on the fuel gauge. It takes a special one. It draws a very small amount of current. The wrong resister would be as bad as hooking it up direct.
1972 Chevy c10 Cheyenne Super
#94970 03/09/2006 12:52 AM
I just tested this arrangement on the bench after I figured out the correct dropping resistor for the radio. The gas gauge draws around 200 Ma or .2 A and so a resistor of 30 to 35 ohms will do the trick very nicely. The rating should be greater than 1 watt, so a 2 watt one would do.
As far as your mentioning that something was attached to the ammeter, certain accessories were fed from the ammeter terminal using an inline fuse. No add-ons should ever be fed from there without a fuse.
1951 1 Ton Completed
A Runtz from Fifth Avenue will fix your fuel gauge. Most of us with the exception of Tiny would have the misfortune of frying the gas gauge within 100 miles if we failed to install a reducer. Clint Eastwood had better stay away from Tint. Not only does he feel lucky...he is lucky and Clint may be in for a surprise!!
