1 members (klhansen),
136
10
Mod | | | Forums66 Topics128,281 Posts1,058,470 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2013 Posts: 30 'Bolter | | 'Bolter Joined: May 2013 Posts: 30 | Can someone tell me where I can get a center section( 3.36 )or similar for my 1958 chevy truck? | | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | Are you talking about the carrier that the ring gear bolts on to? There are 3.38 gear sets available. http://www.ringpinion.com/b2c/Produ...mp;Brand=Yukon_Gear_Ring_and_Pinion_SetsAnd this is a good place to look for other parts too.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | Most times the center section, or "pumpkin", or what is the actual differential is a 3.90 in the earlier trucks. One might get lucky sometimes and get another gear. Especially if it is an Automatic vehicle. I recently was given a 59 rear end and what a surprise when I pulled the cover and found out it was a 3.08. You just never know. Around in my area a junk yard will want as much as a couple hundred for the rearend but you won't know the gear ratio. I've got a 3.90 center section you can have if you want it but it whine's going down the road. If you want it and then change ring gear/pinion send me a PM. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | lancer, if you have the punkin and carrier [or want to scoop chips] you might find the 3.38 gears for the TF [55-59] trucks at a shop nearby that specializes in rear ends and transmissions
Bill | | |
