Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (Pre '68 Dave, 3B, kades51, TooMany2count, 1 invisible), 130 guests, and 3 robots.
Topics128,283
Posts1,058,513
Members48,490
#949154 06/09/2013 2:47 PM
Hello everyone, has anyone here swapped the original gears to 3.38? I heard its better for top speed and less high rpm on stock 235 motor. Anything I need to look out for? Thanks in advance.
matt55 #949176 06/09/2013 6:21 PM
I changed the rear end gears from 4.11 to around the 3.38 range in my 39 with a 216 engine and 3 speed trans. Top speed before the change was 45 mph with the engine screaming. Now it'll cruise 55-60 mph without the engine complaining. There is a difference taking off from a stop, but not enough to make it troublesome.
1939 Chevrolet Stake Truck
matt55 #949209 06/09/2013 9:21 PM
higher gears are good for the hi way, lower for take off and towing.. I had a 235 four speed with 3:55 gears,
it was quick and would run great at hi way speeds
probably about 3,000 rpm at 60 mph..engine would whine some but
never had any problem with it... a lot depends on how you want to drive the truck for, etc
later changed out with a five speed and blazer rear end 2:73
would run 70 plus mph at 2000 rpm...better by a lot, little slow in first gear but did ok, would have to shift out of fifth gear for bigger hills............gas mileage went from 13 or so to high 19 plus
Redryder pix
My Hotrod
matt55 #949231 06/09/2013 10:19 PM
I put 3.38s in Cliff59's truck and he's happier than a pig in a hog waller. I hope he chimes in on this.
matt55 #949239 06/09/2013 10:43 PM
Thanks for the input guys. Any preferred place to buy the gears? Any brands I should stay away from?
matt55 #949344 06/10/2013 3:11 PM
I would agree with charley, 338 would be about perfect for all around performance
Redryder pix
My Hotrod
matt55 #949545 06/11/2013 8:27 AM
I put 3.38 gears in my 1957 NAPCO. Bought them from Patrick's. A real gentleman and never minded my phone calls for help. He answered my questions directly and even called back a time or two. Since I bought two sets of gears, he gave me a break on the second set. I don't think you can go wrong buying from him.
don
matt55 #949787 06/12/2013 4:52 AM
i did this swap a couple of months ago and i really like the results.
gear swap
matt55 #950157 06/13/2013 3:32 PM
I just bought these( http://www.ringpinion.com/b2c/Produ...eType=&DiffId=&Source=DiffWizard ) for my '59 Apache with a 250 and a 3 speed in it. I am waiting for a friend of mine to set them up for me so I haven't got them in yet. It was the best price I could find though.
Gene
1959 Apache
matt55 #950253 06/13/2013 11:52 PM
I think you'll like the Yukon gears. I used their 3.08 ring gear.
GeneWiseman #950275 06/14/2013 5:32 AM
Originally Posted by GeneWiseman
that's where i got my set. i agree, its the best deal i could find
matt55 #950399 06/14/2013 10:38 PM
Thanks for the link, definitely going to be my next upgrade, calling shops in my area and got a quote for 1000.00. They told me that's with new seals, bearings, does that sound like a fair price?
matt55 #950415 06/14/2013 11:48 PM
Sounds a bit high to me but then again you live in Ca. and that probably makes a difference than here in the South.
matt55 #950425 06/15/2013 12:55 AM
matt - is that just the parts, or installation as well?
matt55 #950504 06/15/2013 3:39 PM
i provided the ring and pinion set and paid about $500 for parts & labor to have a transmission shop set up the center section (lash) and put in new seals and bearings. i installed it into the axle housing myself.
matt55 #950520 06/15/2013 5:02 PM
Thats installed out the door, everything included.
Donsz #950525 06/15/2013 5:16 PM
I'll be damned (sorry, can I say that here? If not, I'll be darned then)
Bought 355:1 gears to replace the 411 from Patrick approx 20 years ago and didn't realize he now offers a taller differential package. Will be following that up
Bless you
sandra
matt55 #950526 06/15/2013 5:24 PM
Sandra, the 3.38's Patrick has are for the TF series
Matt - a thou installed is a decent price, that's what a rear gear shop up here quoted 5 years ago
