2 members (WICruiser, Joe H),
148
Mod | | | Forums66 Topics128,283 Posts1,058,513 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 29 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 29 | Hello everyone, has anyone here swapped the original gears to 3.38? I heard its better for top speed and less high rpm on stock 235 motor. Anything I need to look out for? Thanks in advance. | | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | I changed the rear end gears from 4.11 to around the 3.38 range in my 39 with a 216 engine and 3 speed trans. Top speed before the change was 45 mph with the engine screaming. Now it'll cruise 55-60 mph without the engine complaining. There is a difference taking off from a stop, but not enough to make it troublesome.
1939 Chevrolet Stake Truck
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | higher gears are good for the hi way, lower for take off and towing.. I had a 235 four speed with 3:55 gears, it was quick and would run great at hi way speeds probably about 3,000 rpm at 60 mph..engine would whine some but never had any problem with it... a lot depends on how you want to drive the truck for, etc
later changed out with a five speed and blazer rear end 2:73 would run 70 plus mph at 2000 rpm...better by a lot, little slow in first gear but did ok, would have to shift out of fifth gear for bigger hills............gas mileage went from 13 or so to high 19 plus Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I put 3.38s in Cliff59's truck and he's happier than a pig in a hog waller. I hope he chimes in on this. | | | | | Joined: Oct 2012 Posts: 29 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 29 | Thanks for the input guys. Any preferred place to buy the gears? Any brands I should stay away from? | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I would agree with charley, 338 would be about perfect for all around performance Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I put 3.38 gears in my 1957 NAPCO. Bought them from Patrick's. A real gentleman and never minded my phone calls for help. He answered my questions directly and even called back a time or two. Since I bought two sets of gears, he gave me a break on the second set. I don't think you can go wrong buying from him. don | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | i did this swap a couple of months ago and i really like the results. gear swap | | | | | Joined: Apr 2012 Posts: 124 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 124 | I just bought these( http://www.ringpinion.com/b2c/Produ...eType=&DiffId=&Source=DiffWizard ) for my '59 Apache with a 250 and a 3 speed in it. I am waiting for a friend of mine to set them up for me so I haven't got them in yet. It was the best price I could find though.
Gene 1959 Apache
| | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | I think you'll like the Yukon gears. I used their 3.08 ring gear. | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | that's where i got my set. i agree, its the best deal i could find | | | | | Joined: Oct 2012 Posts: 29 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 29 | Thanks for the link, definitely going to be my next upgrade, calling shops in my area and got a quote for 1000.00. They told me that's with new seals, bearings, does that sound like a fair price? | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | Sounds a bit high to me but then again you live in Ca. and that probably makes a difference than here in the South. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | matt - is that just the parts, or installation as well?
Bill | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | Thanks for the link, definitely going to be my next upgrade, calling shops in my area and got a quote for 1000.00. They told me that's with new seals, bearings, does that sound like a fair price? i provided the ring and pinion set and paid about $500 for parts & labor to have a transmission shop set up the center section (lash) and put in new seals and bearings. i installed it into the axle housing myself. | | | | | Joined: Oct 2012 Posts: 29 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 29 | Thats installed out the door, everything included. | | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | I'll be damned (sorry, can I say that here? If not, I'll be darned then)
Bought 355:1 gears to replace the 411 from Patrick approx 20 years ago and didn't realize he now offers a taller differential package. Will be following that up
Bless you
sandra | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Sandra, the 3.38's Patrick has are for the TF series
Matt - a thou installed is a decent price, that's what a rear gear shop up here quoted 5 years ago
Bill | | |
