Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (Peggy M, Hambone, 68ironhead, 2-Ton, TUTS 59, DaveV, msmall), 54 guests, and 2 robots.
Topics128,009
Posts1,055,296
Members48,419
#94906 03/01/2006 11:03 PM
I'm putting a 292 in my AD. I wanna powerwash the interior, but want to wait until spring and warm weather. Obviously, I won't rewire until after that. Here's my question - once I mount the engine, is there a half [censored] wiring job I can do to get the motor started? Don't care about the proper connectors or anything, just - can it be done? Thanks in advance,
jay
Your lack of preparation is not my emergency
#94907 03/01/2006 11:29 PM
Bare bones you will need power to the starter and the ignition. That is if there are no computer components.
Fred
52 3600
69 C-10
#94908 03/01/2006 11:32 PM
Yes Jay there is.Run a jumper wire from the positive side of the battery to the positive side of the coil.Now the next step is very important!! Make sure your AD is in neutral,the rear wheels are off the ground or you can out run your truck when it takes off without you.With a screw driver or metal rod jump the solinoid(if you have one)to engage the starter or stomp on the foot starter.I would hook up some gauges to keep an eye on oil pressure and water temp.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#94909 03/01/2006 11:37 PM
Thanks guys!! I guess I don't need the alternator, and I can just use the battery for a few seconds, right? There is no computer stuff, either.
jay
#94910 03/02/2006 9:08 AM
Yup. The alternator went out in the 292 in my 59 and I have been charging the truck on the battery charger to keep it going for errands until I can monkey with it. There is very little draw on the battery after the starter has done its business.
