7 members (Peggy M, Hambone, 68ironhead, 2-Ton, TUTS 59, DaveV, msmall),
54
Mod | | | Forums66 Topics128,009 Posts1,055,296 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94906 03/01/2006 11:03 PM | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | I'm putting a 292 in my AD. I wanna powerwash the interior, but want to wait until spring and warm weather. Obviously, I won't rewire until after that. Here's my question - once I mount the engine, is there a half [censored] wiring job I can do to get the motor started? Don't care about the proper connectors or anything, just - can it be done? Thanks in advance,
jay
Your lack of preparation is not my emergency
#94907 03/01/2006 11:29 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Bare bones you will need power to the starter and the ignition. That is if there are no computer components.
Fred 52 3600 69 C-10
#94908 03/01/2006 11:32 PM | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Yes Jay there is.Run a jumper wire from the positive side of the battery to the positive side of the coil.Now the next step is very important!! Make sure your AD is in neutral,the rear wheels are off the ground or you can out run your truck when it takes off without you.With a screw driver or metal rod jump the solinoid(if you have one)to engage the starter or stomp on the foot starter.I would hook up some gauges to keep an eye on oil pressure and water temp.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#94909 03/01/2006 11:37 PM | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | Thanks guys!! I guess I don't need the alternator, and I can just use the battery for a few seconds, right? There is no computer stuff, either.
jay
#94910 03/02/2006 9:08 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | Yup. The alternator went out in the 292 in my 59 and I have been charging the truck on the battery charger to keep it going for errands until I can monkey with it. There is very little draw on the battery after the starter has done its business. | | |
