6 members (jmoore, joe apple, Gdads51, 3B, Rusted Nut, 68ironhead), 112 guests, and 3 robots.
Topics128,264
Posts1,058,350
Members48,485
#94871 02/28/2006 1:46 AM
This might be a dumb question but here goes anyway. Will the 6 volt amp guage work all right on 12 volts or does it need a voltage reducer in line? Its on a 51 chevy.
#94872 02/28/2006 2:38 AM
Amps is amps. It don't care about volts.
#94873 02/28/2006 4:20 AM
What cletis said.
and it's an Ammeter, not an AMP gauge.
#94874 02/28/2006 8:12 AM
You can think of it like water. Volts are the speed of the water, AMPs are volume of water passing through. So when headlights or starter goes - it takes a lot of 'water' to make them go.
And that's why it takes a big hose (heavy gauge wire) to things that use a lot of 'water' or 'current'. Eh eh eh? Get it? Big pipe, lots o water, lots o amps, lots o current?
