Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (1955 1 Series, farmallb, baldeagle, Dennys28, cmayna), 63 guests, and 3 robots.
Topics128,004
Posts1,055,265
Members48,418
#948591 06/06/2013 7:55 PM
took my 235 out today and after installing a new carb and new fuel pump i am running rich , i can tell by the smell now i have adjusted the choke and fast idle and air mixture and floats ,, what else can i do , it starts ok and runs ok only at idle it does this i can even see a tad bit of smoke ,
thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #948629 06/06/2013 10:00 PM
Riding in the Passing Lane
There is a vacuum hole in the bottom of the carb. There must be a passage in the gasket to allow vacuum to get to this hole. You say "new" carb. It probably is a rebuilt or reman. Most of the time they are not right. You need to check the float level & make sure the power valve is working correctly. Its possible it has the wrong size main jet in it.
1972 Chevy c10 Cheyenne Super
lilrobo #948691 06/07/2013 6:22 AM
The float is fine, i dont know about the jets? I did use the base gasket with small ports that came with carb, i have 2 carbs form rock auto, they sent me 2 . I need to send 1 back after i get it running, ,,1 carb had 2 gaskets they said it was due to maybe being warped, but they are checked out on the bench, but i went with the one with 1 gasket, i guess i could get the jet from my origianal carb i changed for other reasons , so it mighthave the right jet
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
