3 members (RoadsScholar, Otto Skorzeny, 1 invisible), 197 guests, and 4 robots.
Topics128,108
Posts1,056,231
Members48,436
I'm starting to over heat again in these warmer days and am thinking of putting an electric fan in front of the radiator. Anyone done that with good results? This would be for a 49 half ton.
I called a local shop to see about a recore job and they said about $400 or more. Still running the stock fan blade so maybe the newer design would be better and maybe fabbing up a shroud would be the way to go.
Temp difference between top/bottom tank is about 15 deg. Likely that is ok for these trucks ?
Also planning to re-gear the dif to 3.55 so that should help too.
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
what year? what engine? if everything is stock, overheating indicates something wrong, no point using band-aids ... if you add an electric fan, remove the stock one, but it's unlikely to prevent overheating on a stock truck that tends that way
Bill,
My bad...I shoulda said it has a 235 from a '56. Otherwise it's stock. I'm pretty suspicious that the rad. is in a bad way. Been looking into an alum replacement. I agree, the fan will be a band aid.
Mark
1949 Chevy 1/2-Ton
Lucielle
I agree with Red58. Chase the problem, not the effect. That 400 bucks would be better spent on the new radiator. A shroud for the stock fan will help a lot. BTW, it is not recommended to use both a pusher and puller fans. It sets up a vortex between the two fans to actually reduce air flow.
