| | | Forums66 Topics128,091 Posts1,056,390 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | I'm starting to over heat again in these warmer days and am thinking of putting an electric fan in front of the radiator. Anyone done that with good results? This would be for a 49 half ton.
I called a local shop to see about a recore job and they said about $400 or more. Still running the stock fan blade so maybe the newer design would be better and maybe fabbing up a shroud would be the way to go.
Temp difference between top/bottom tank is about 15 deg. Likely that is ok for these trucks ?
Also planning to re-gear the dif to 3.55 so that should help too.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | what year? what engine? if everything is stock, overheating indicates something wrong, no point using band-aids ... if you add an electric fan, remove the stock one, but it's unlikely to prevent overheating on a stock truck that tends that way
Bill | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Bill, My bad...I shoulda said it has a 235 from a '56. Otherwise it's stock. I'm pretty suspicious that the rad. is in a bad way. Been looking into an alum replacement. I agree, the fan will be a band aid.
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I agree with Red58. Chase the problem, not the effect. That 400 bucks would be better spent on the new radiator. A shroud for the stock fan will help a lot. BTW, it is not recommended to use both a pusher and puller fans. It sets up a vortex between the two fans to actually reduce air flow.
