Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (BC59, TooMany2count, Otto Skorzeny), 116 guests, and 4 robots.
Topics128,277
Posts1,058,441
Members48,490
#947854 06/04/2013 4:31 AM
Here is a picture of my steering column, Is the replacement bushing from classic parts 91-061, picture is linked also. Thanks Steve
http://s1321.photobucket.com/user/s...kage_zps03b3b116.jpg.html?sort=3&o=0
http://s1321.photobucket.com/user/s...ank_zps2088e4ef.jpg.html?sort=3&o=11
Those are the correct bushings. The larger diameter end is mounted in the hole on the top of the shift lever arms.
I would suggest that you buy an extra set of the rubber ones for the glove box as they wear out and will cause a misalignment in the shifter box causing your transmission to lock up in gear. If this happens you can open the hood and manually line up the column shifter arms and unlock it. I made mine out of brass. I now have a better feel of how everything moves during a shift and they won't wear out.
thanks for the info. Steve
