4 members (MikeE, lc_btv, Oldcaliforniakid, Rexville48), 104 guests, and 3 robots.
Topics128,050
Posts1,055,673
#944018 05/18/2013 9:12 AM
Does anyone have any extra rod shims they would be willing to part with? Can't seem to find a source for new ones
Bolter2 #944034 05/18/2013 10:54 AM
Can't help wit a source, but here's some part numbers to look for:
Federal-Mogul shim set: FSM 104S
TRW: SM 104S
Main bearing shims:
F-M: FSM 105S
TRW: SM 105S
Edit: Try this link- - -they've got both rod and main shims (rod bearing shims are labeled wrong- - -104 is NOT a main bearing shim!):
http://frugalmechanic.com/auto-part/sealed-power-fsm104s-main-bearing
Bolter2 #944061 05/18/2013 1:31 PM
Denny, which temper would you recommend? Thanks Don
Hotrod Lincoln #944068 05/18/2013 2:06 PM
Thanks Hot Rod! You come thru with the answer again
Bolter2 #944069 05/18/2013 2:12 PM
Bolter2 #944071 05/18/2013 2:27 PM
Chevs of the 40's sight states that their shims are .009. The broken shims off my rods measure .002
Bolter2 #944085 05/18/2013 3:57 PM
What about this set - 364322?
364322 is also sold by Tim Tygart - give him a call about the thickness?
Shim set 364322 seems to have .002 shims?
"1929-1954 Connecting Rod Shims (set of 12) These four-ply laminated brass shims of 0.002 in./ply are essentially identical to the original shims but are plastic laminated to facilitate separation. Packaged in full engine sets... p/n 364322 ...$16.00set"?
tclederman #944147 05/18/2013 8:57 PM
Thanks tclederman! Looks like your on the money with that selection. I will will double check but those look like the real deal. Thanks again!
Bolter2 #944150 05/18/2013 9:09 PM
Check the last link in my post, Bolter2
Should be about $20 including shipping to western Michigan
I know nothing about that seller.
Here is another low price.
Bolter2 #944155 05/18/2013 9:26 PM
I just orded rod shims from the Filling Station. I have my fingers crossed. Last time I needed some I used .001 and .002 brass shim stock from Carquest.
1951 1 Ton Completed
Bolter2 #944224 05/19/2013 7:37 AM
truckernix,
Those shims should be 0.0032.
"CONNECTING ROD SHIMS
Set of 12 - 4-ply Brass in .002 Incremen
These four-ply laminated brass shims of .002 in./ply are essentially identical to the original shims, but are plastic laminated to facilitate separation. Replaces GM# 364322."
However, let us know what you get. Some of the vendors state that their set of shims replace 364322 but they are the .009 set sold be Chevs of the 40s?
Bolter2 #945334 05/23/2013 8:17 PM
Just got the shims I ordered from the guy that tclederman posted a link for. The company is Marx Parts, out of Wisconsin. Same ole' B.S. Claims shims are for '29 to'54 Chevy's, and they show up .009 thick. You would think these companies would do a little research before they sell you something. 49 to 54 service manual clearly states that the 235 comes with two .002 thick shims on each side of the rod. What a bunch of clowns. Time to start drinkin' and then cuttin' up the beer cans afterwards
Bolter2 #945338 05/23/2013 8:49 PM
That might be what all the vendors are now selling for that original part number.
I am checking with "Billy Possum" at C&P Automotive.
Bolter2 #945343 05/23/2013 9:11 PM
Originally Posted by Bolter2
.... You would think these companies would do a little research before they sell you something. ....
or maybe buyers should do a bit of research before buying? you might have asked what the measurement was for the part, or what options were available for a part that's been obsolete for decades
"These four-ply laminated brass shims of 0.002 in./ply are essentially identical to the original shims but are plastic laminated to facilitate separation." sounds like a stack of .002 shims, peel off what you need, .002, .004, .006, .008
Bolter2 #945440 05/24/2013 6:53 AM
yep, heaven forbid you actually get what you paid a ludicrous amount of money for....
Flxible #945442 05/24/2013 7:11 AM
Got news for you red58, got the shims in my hand and there is no peel what ya want. Furthermore, he won't answer e-mails or return phone calls
Bolter2 #945526 05/24/2013 1:45 PM
I bought shims like that a few years ago from one of the major vendors. I think they were .006" thick one piece brass shims. They were absolutely useless. the shocking part was that they were made by Federal Modul.
Bolter2 #945529 05/24/2013 1:55 PM
I was fooled by Federal Mogul main shims once.
I would have sworn they were one thick shim, but when I cut into the edge of the shims with my knife it turned out they were just very well stuck together.
I have a feeling this is the case here.
My Blog
Bolter2 #945546 05/24/2013 3:50 PM
Bolter2, listen to Dave, the description of what was sold should be what you have in your hand, if not then try the same thing from another supplier .... and another ... for the same thing
Bolter2 #946204 05/27/2013 9:15 PM
Well I got my rod shims today and they were just like the ones I bought a few years ago. There are twelve of them and although I haven't measured them yet I am pretty sure they are at least .006". They are not thinner shims stuck together.
Pre'68Dave,
if you PM me an address I will send you one so that you can see what they are selling as shims these days. These things are useless.
truckernix #946213 05/27/2013 9:28 PM
Thank you!
Message sent.
My Blog
Bolter2 #947798 06/03/2013 10:04 PM
Well Fred..
I got the shims in the mail from you today.
As I suspected they are 3 .002" shims very stuck together in each of the two you sent.
I do not understand why they do not inclose instructions with the shims telling you that they are made this way. It would be even better if they came not stuck together.
They are so stuck together it is almost imposable to get apart. Here is a link to one of your shims starting to peel apart.
Thanks, Dave
My Blog
Bolter2 #947800 06/03/2013 10:22 PM
Ahhhh... An Emily Littela moment dang
Give me ambiguity
or give me something else
Bolter2 #947856 06/04/2013 6:20 AM
Dave,
I have been waiting for this moment! I guess I will use a bigger knife! I started on one and it started to bend. Thanks for having a look. I will tear into them now!
Fred
Bolter2 #947904 06/04/2013 10:37 AM
Be VERY careful!
It is almost imposable to divide them.
It is a sure way to cut yourself.
It actually takes a very sharp fine knife to split them.
My Blog
Bolter2 #947915 06/04/2013 11:11 AM
It looks like a job for Exacto Blade to me...
Give me ambiguity
Bolter2 #947916 06/04/2013 11:22 AM
Your right but a Swiss Army Knife can do anything.
My Blog
Pre '68 Dave #948070 06/04/2013 7:33 PM
Your right on two acconts Dave. The scissors on my swiss army knife worked perfectly for cutting my own rod shims out of shim stock. I finally did get the other shims to peel apart, also using my very sharp knife, however, being .0025 thick, I needed other size shim material to get the clearances I wanted. Your also correct about the fact that there are no instructions sent with these things. It also does not help when the supplier will not answer e-mails or phone calls. The shims I recieved were of the Billy Possum brand, and they will peel apart. After I finally suceeded in geeting them apart I had some fun giving a few to my mechanic and machine shop buddies and asking them to make me a .0025 shim out of what they had in their hand
Bolter2 #948138 06/04/2013 10:22 PM
I switched to one of the little utility jobs where you extend the blade and break off the old chunk. Armed with the new knowledge I just gently scraped the edge and they separated. This has been very helpful for me, thanks.
