7 members (48jim1ton, 2-Ton, JW51, Jman, 32Fordpuchoptop, Jay R, Peggy M),
92
Mod | | | Forums66 Topics128,042 Posts1,055,601 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 135 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 135 | Does anyone have any extra rod shims they would be willing to part with? Can't seem to find a source for new ones | | | | | Joined: Feb 2004 Posts: 29,761 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,761 | Can't help wit a source, but here's some part numbers to look for: Federal-Mogul shim set: FSM 104S TRW: SM 104S Main bearing shims: F-M: FSM 105S TRW: SM 105S Jerry Edit: Try this link- - -they've got both rod and main shims (rod bearing shims are labeled wrong- - -104 is NOT a main bearing shim!): http://frugalmechanic.com/auto-part/sealed-power-fsm104s-main-bearingJerry
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Denny, which temper would you recommend? Thanks Don | | | | | Joined: Apr 2012 Posts: 135 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 135 | Thanks Hot Rod! You come thru with the answer again | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Apr 2012 Posts: 135 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 135 | Chevs of the 40's sight states that their shims are .009. The broken shims off my rods measure .002 | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What about this set - 364322? 364322 is also sold by Tim Tygart - give him a call about the thickness? Shim set 364322 seems to have .002 shims? "1929-1954 Connecting Rod Shims (set of 12) These four-ply laminated brass shims of 0.002 in./ply are essentially identical to the original shims but are plastic laminated to facilitate separation. Packaged in full engine sets... p/n 364322 ...$16.00set"? | | | | | Joined: Apr 2012 Posts: 135 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 135 | Thanks tclederman! Looks like your on the money with that selection. I will will double check but those look like the real deal. Thanks again! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Check the last link in my post, Bolter2 Should be about $20 including shipping to western Michigan I know nothing about that seller. Here is another low price. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I just orded rod shims from the Filling Station. I have my fingers crossed. Last time I needed some I used .001 and .002 brass shim stock from Carquest. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | truckernix,
Those shims should be 0.0032.
"CONNECTING ROD SHIMS Set of 12 - 4-ply Brass in .002 Incremen These four-ply laminated brass shims of .002 in./ply are essentially identical to the original shims, but are plastic laminated to facilitate separation. Replaces GM# 364322."
However, let us know what you get. Some of the vendors state that their set of shims replace 364322 but they are the .009 set sold be Chevs of the 40s?
| | | | | Joined: Apr 2012 Posts: 135 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 135 | Just got the shims I ordered from the guy that tclederman posted a link for. The company is Marx Parts, out of Wisconsin. Same ole' B.S. Claims shims are for '29 to'54 Chevy's, and they show up .009 thick. You would think these companies would do a little research before they sell you something. 49 to 54 service manual clearly states that the 235 comes with two .002 thick shims on each side of the rod. What a bunch of clowns. Time to start drinkin' and then cuttin' up the beer cans afterwards | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That might be what all the vendors are now selling for that original part number.
I am checking with "Billy Possum" at C&P Automotive.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | .... You would think these companies would do a little research before they sell you something. .... or maybe buyers should do a bit of research before buying? you might have asked what the measurement was for the part, or what options were available for a part that's been obsolete for decades " These four-ply laminated brass shims of 0.002 in./ply are essentially identical to the original shims but are plastic laminated to facilitate separation." sounds like a stack of .002 shims, peel off what you need, .002, .004, .006, .008 Bill | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | yep, heaven forbid you actually get what you paid a ludicrous amount of money for.... | | | | | Joined: Apr 2012 Posts: 135 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 135 | Got news for you red58, got the shims in my hand and there is no peel what ya want. Furthermore, he won't answer e-mails or return phone calls | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I bought shims like that a few years ago from one of the major vendors. I think they were .006" thick one piece brass shims. They were absolutely useless. the shocking part was that they were made by Federal Modul. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I was fooled by Federal Mogul main shims once. I would have sworn they were one thick shim, but when I cut into the edge of the shims with my knife it turned out they were just very well stuck together. I have a feeling this is the case here.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Bolter2, listen to Dave, the description of what was sold should be what you have in your hand, if not then try the same thing from another supplier .... and another ... for the same thing
Bill | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Well I got my rod shims today and they were just like the ones I bought a few years ago. There are twelve of them and although I haven't measured them yet I am pretty sure they are at least .006". They are not thinner shims stuck together.
Pre'68Dave, if you PM me an address I will send you one so that you can see what they are selling as shims these days. These things are useless.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Well Fred.. I got the shims in the mail from you today. As I suspected they are 3 .002" shims very stuck together in each of the two you sent. I do not understand why they do not inclose instructions with the shims telling you that they are made this way. It would be even better if they came not stuck together. They are so stuck together it is almost imposable to get apart. Here is a link to one of your shims starting to peel apart. Thanks, Dave
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Ahhhh... An Emily Littela moment
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Dave, I have been waiting for this moment! I guess I will use a bigger knife! I started on one and it started to bend. Thanks for having a look. I will tear into them now!
Fred | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Be VERY careful! It is almost imposable to divide them. It is a sure way to cut yourself. It actually takes a very sharp fine knife to split them.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | It looks like a job for Exacto Blade to me...
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Your right but a Swiss Army Knife can do anything.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2012 Posts: 135 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 135 | Your right on two acconts Dave. The scissors on my swiss army knife worked perfectly for cutting my own rod shims out of shim stock. I finally did get the other shims to peel apart, also using my very sharp knife, however, being .0025 thick, I needed other size shim material to get the clearances I wanted. Your also correct about the fact that there are no instructions sent with these things. It also does not help when the supplier will not answer e-mails or phone calls. The shims I recieved were of the Billy Possum brand, and they will peel apart. After I finally suceeded in geeting them apart I had some fun giving a few to my mechanic and machine shop buddies and asking them to make me a .0025 shim out of what they had in their hand | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I switched to one of the little utility jobs where you extend the blade and break off the old chunk. Armed with the new knowledge I just gently scraped the edge and they separated. This has been very helpful for me, thanks. | | |
