| | | Forums66 Topics128,030 Posts1,055,423 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94750 02/22/2006 1:38 AM | Joined: Nov 2005 Posts: 16 Junior Member | | Junior Member Joined: Nov 2005 Posts: 16 | Hello to all, This 65 electrical problems are driving me crazy! First posted 'dead truck' and replaced battery, alternator, voltage reg, and brand new alt. wiring harness, along with instrument cluster harness. Now i have no tail lights and only a faint rt signal and no lt signal. Replaced the tail light harness and still no luck. What the hell?
Patrick | | |
#94751 02/22/2006 1:43 AM | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | Sounds like a "grounding" issue. | | |
#94752 02/22/2006 1:44 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | check/redo all the grounds, especially at the back - make sure the tail light pots and bed have GOOD grounds and see what happens
Bill | | |
#94753 02/22/2006 3:05 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | check where it plugs in at the firewall. | | |
#94754 02/22/2006 9:03 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | And it wouldn't hurt to be sure the bed is solidly grounded to the frame. I seriously wire brushed a spot on the frame and on the bed of my truck and put a battery ground strap there,then sprayed it with battery terminal protector. A good ground on your taillight pots won't help if the bed isn't grounded. Like Bill has said,most taillight,turn signal and stoplight problems can be traced to a bad ground somewhere. Speed | | |
