7 members (Hotrod Lincoln, mo2cyl, Woodcmiami, 66flea, DadsFirstPickup, 5 Window 9434, 1 invisible),
102
Mod | | | Forums66 Topics128,049 Posts1,055,662 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 15 New Guy | | New Guy Joined: Jan 2011 Posts: 15 | Am converting to power steering on 1961 c10. Am using 1985 c10 power steering gear box from salvage yard. Am hooking up new hoses and cannot figure where high pressure and low pressure hoses go account the input fittings are same on the box. Thank all for the answer to this vexing question. | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | They may look the same but if it's the stock gear box, they are different.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | '80 & newer gear boxes, have metric hose fittings, so make sure you have the corresponding pump, so you don't have to have special high/low hoses made. Also, the high pressure and low return line, have different size fittings, so they can not be switched.
| | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Where the return line attaches to the pump nothing is needed but a small hose clamp. On the pressure side, there are adapters that screw in that allow early pumps on late boxes and vise versa.
best wishes,
Les | | |
