3 members (Danielbolt, bluechev, 1 invisible), 104 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,456
Junior Member
Junior Member
I just finished reading the thread about the heater switch, and how it works. I understand all that. My question is where does the darn resistor mount in a '62, non-deluxe heater? When I bought my truck, there was no resistor. Just a jumper across the terminals that gave me wide open speed. The resistor is not mounted to the back of the switch like it was on A/D trucks. I think that it mounts to the fan housing somewhere, but, I can't tell where. Any help and/or pics will be appreciated.
Mark
1962 Stepside
1948 GMC
1969 Chevelle
http://mgiles5.photosite.com/
hey Mark, welcome to the fray!
can't tell ya just where it mounts as I haven't had a 60's model in awhile, but the controls should have a slider type switch like such and the seperate resistor looks like here - I'd bet that there'll be about 4 wires off the switch - 1 to power, 2 to the resistor, 1 to the motor - the resistor would then have 1 to the motor - switch would have off, lo, med, high with the lo and med going thru 1/2 or all of the resistor - no idea where it would mount, but I'd think maybe inside the heater case
usually mounts on the backside of the heater/defrost plenum, can't really see it until you remove plenum,brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
You don't really have to see it to install it. You can install it by feel pretty easily.
If it's like the one I just installed,it has 3 wires to it,and does go on the back of the heater plenum. Reaching back just left of the heater motor,you'll feel a rectangular hole with 2 tabs sticking out. The coil sring side goes into the hole,and the board snaps into the tabs.(tight fit-you may have to pry on the tabs to get the board to snap in.) Then just connect the 3 wire plug and it works.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
Junior Member
Junior Member
Speed,
That sounds right, but I think that my board is too wide. The coils fit into that slot with no problem. I'll try it again tomorrow when I have more time. Thanks Bill and 64fleetside for the timely responses.
Mark
1962 Stepside
1948 GMC
1969 Chevelle
The board won't go into the hole-just the coils. Then the 2 tabs on the outside of the plenum squeeze the edges of the board to hold everything in place. You'll notice the board has kind of an hourglass shape;the narrow spots are to register the board in the tabs. As I said,it's a very tight fit,so you might have to reach back there and pry one tab outward while you push the board under it.
Not a fun job,but far from the worst one.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'84 Bronco II
'78 Dodge W-200
