6 members (Phak1, Gray_Ghost, WICruiser, Ponchogl, Otto Skorzeny, GMCJammer51), 148 guests, and 1 robot.
Topics128,105
Posts1,056,551
Members48,448
Having converted my 49 half ton to IFS with front disc set up and power boosted two chamber MC I'm still disappointed with the brakes. The peddle just does not even begin to apply braking until I'm a bit over half way to the floor ! To me, that's more than a bit unacceptable cuz there's not that much peddle left when I stop. Before I began this upgrade there was plenty of peddle but that was with 1949 technology, single chamber MC, and all the rest that was stock in 49.
My wrench guy is good but really frustrated and at a loss at what to do to improve the situation. Am I expecting too much here ? It just makes me goosey to be so near the floor before I get a firm stop. The MC was bench bled and all four wheels bled in succession. The MC and boost set up is from a 67 Corvette power brake system...all NIB. Disc front..drum rear.
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
make sure you have enough vac to operate the booster. also check the adjustment of your rear pads. I have had this problem before and it has always been one of the two.
daren
1952 GMC 1-Ton
1946 plymouth
1947 ford
custom builder
http://www.doublegcustoms.com
Dogface;
Did you switch the proportioning valve. Not sure of the details but when you swap in one set of discs and leave a set of drums the valve is different. If you bought the IFS as a kit, the valve is usually included. If it was a bone yard find, you'll need a new one. Hopefully someone that knows the specifics will post.
Just a thought.
Larry
Not enough vacuum will cause a hard pedal not a low one. Assuming all the air is truly out of the system, I would adjust up the rear brakes first. Then, check if there is an adjustment on the rod between the pedal and the mc. Next i would isolate both calipers and rear wheel cyl from the master, Then see if your pedal is solid. if it is, you have a problem at one of the wheels. isolate them individually to determine which wheel your problem is at.
I agree with JCKN, isolate will make it easier to diagnose .
daren
1952 GMC 1-Ton
1946 plymouth
1947 ford
custom builder
Is your brake booster and set up now on the firewall, or still under the truck?
Did you install a 2 pound residual valve for the front brakes and a 10pound residual valve for the rear drum brakes?
Booster and MC are underneath. I'll have to ask about the residual valves...
Mark
1949 Chevy 1/2-Ton
Lucielle
