0 members (),
97
Mod | | | Forums66 Topics128,132 Posts1,056,729 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Having converted my 49 half ton to IFS with front disc set up and power boosted two chamber MC I'm still disappointed with the brakes. The peddle just does not even begin to apply braking until I'm a bit over half way to the floor ! To me, that's more than a bit unacceptable cuz there's not that much peddle left when I stop. Before I began this upgrade there was plenty of peddle but that was with 1949 technology, single chamber MC, and all the rest that was stock in 49.
My wrench guy is good but really frustrated and at a loss at what to do to improve the situation. Am I expecting too much here ? It just makes me goosey to be so near the floor before I get a firm stop. The MC was bench bled and all four wheels bled in succession. The MC and boost set up is from a 67 Corvette power brake system...all NIB. Disc front..drum rear. | | | | | Joined: Apr 2008 Posts: 133 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 133 | make sure you have enough vac to operate the booster. also check the adjustment of your rear pads. I have had this problem before and it has always been one of the two.
daren | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | Dogface;
Did you switch the proportioning valve. Not sure of the details but when you swap in one set of discs and leave a set of drums the valve is different. If you bought the IFS as a kit, the valve is usually included. If it was a bone yard find, you'll need a new one. Hopefully someone that knows the specifics will post.
Just a thought.
Larry
| | | | | Joined: Oct 2012 Posts: 38 New Guy | | New Guy Joined: Oct 2012 Posts: 38 | Not enough vacuum will cause a hard pedal not a low one. Assuming all the air is truly out of the system, I would adjust up the rear brakes first. Then, check if there is an adjustment on the rod between the pedal and the mc. Next i would isolate both calipers and rear wheel cyl from the master, Then see if your pedal is solid. if it is, you have a problem at one of the wheels. isolate them individually to determine which wheel your problem is at. | | | | | Joined: Apr 2008 Posts: 133 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 133 | I agree with JCKN, isolate will make it easier to diagnose .
daren | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Is your brake booster and set up now on the firewall, or still under the truck?
Did you install a 2 pound residual valve for the front brakes and a 10pound residual valve for the rear drum brakes? | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Booster and MC are underneath. I'll have to ask about the residual valves... | | |
