2 members (Nick in Manitou, 1 invisible), 350 guests, and 5 robots.
Topics128,162
Posts1,057,042
Members48,460
I was comparing the mounting location from drivers side to passenger side. On the drivers side, the holes through the cowl match the inner support plate holes. On the passenger side, it looks almost as if the mirror was added as an afterthought?? Both holes are about 3/8" above the inner support plate holes with the upper screw hole moved towards the front of the vehicle by 1/4". Both holes were drilled without the inside being deburred. Normal? I can see where it puts the passenger mirror in a better line of sight for the driver as it kicks the whole assembly up a little higher. Thoughts?
Mark,
You most likely have correctly concluded that the mirror was not put in the GM-intended position. The GM outside mirror-arm on the passenger side has an odd bend to it.
The holes for the GM mirror arms are in similar locations on both sides of the cab. If you look under the dash, you'll see a small brace with holes in it - those holes are where the mirror holes are drilled
The driver's side mirror was standard equipment. The passenger side mirror was a factory option, or an accessory installed by the dealer/owner. Sounds like you have a home-job right-side mirror on your truck?
Thanks Tim!
The arm is stock and as old as the truck. Since it is really close to the stock location, I will leave it as is.
Mark, the outside passenger mirror is "deformed" so that you can look through the right side windshield and be able to see whats going on behind you.
Hey Alvin, the issue isn't the arm. I was more curious about how it is mounted. The positioning is actually really good. I should be able to see it out the passenger window just fine!
Looking at mine I'd say you have right where it goes. I hadn't drilled the holes in mine yet but you can see its the same.
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/100_1398.jpg
....your keeping your project moving. Before long you'll be "on the road again"
I try not to get too excited. Steady as she goes. I try to get at least an hour a day on it. More when I have time on the weekends.
