1 members (TrknGMC),
31
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | so the running boards should be bolted to the rear fender with a rubber gasket between?
my 53 3100 had no holes in the back fenders | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I have never seen a running board thats fits flush to the rear fender NOT have support bolts. Especially for a truck where one is likley to use the rear of the running board to access the bed. If they are not there I would add them. The gap between the two is usually filled with a welting strip. Welt strips looks like (to me) a 1" piece of vinyl wraped around a piece of plastic clothesline.
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I used welting between my boards and fender bottoms - helps close the gaps a little, and prevents metal / metal contact. My boards do bolt up to the fenders - 1/4" bolts I think. Won't take much load but pull everything together. The brackets under the boards handle the loads. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | A welting would work. This gasket was used. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Yeah, it was originally a rubber gasket, and on a 53 they should be bolted. | | |
