Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (wvstovebolt), 31 guests, and 3 robots.
Topics128,009
Posts1,055,293
Members48,419
#945439 05/24/2013 6:52 AM
so the running boards should be bolted to the rear fender with a rubber gasket between?
my 53 3100 had no holes in the back fenders
I have never seen a running board thats fits flush to the rear fender NOT have support bolts. Especially for a truck where one is likley to use the rear of the running board to access the bed. If they are not there I would add them. The gap between the two is usually filled with a welting strip. Welt strips looks like (to me) a 1" piece of vinyl wraped around a piece of plastic clothesline.
I used welting between my boards and fender bottoms - helps close the gaps a little, and prevents metal / metal contact. My boards do bolt up to the fenders - 1/4" bolts I think. Won't take much load but pull everything together. The brackets under the boards handle the loads.
1940 Chevy KC 1/2-Ton
A welting would work. This gasket was used.
Yeah, it was originally a rubber gasket, and on a 53 they should be bolted.
My 46 GMC on Photobucket
