4 members (Southerntruck, 5cameo8, Jack Ryan, Bill Hanlon), 124 guests, and 2 robots.
Topics128,089
Posts1,056,418
Members48,443
#944994 05/22/2013 10:44 AM
So I took a small chip out of the paint putting on the fender. 1/4 inch by 3/4 inch.
What is the best way to touch this up?
Can I mix up some paint and lightly brush it in place with a artists brush?
I know it would not be 100% but it is metallic.
It's your call, it will show, the ? Is how much do you care? Metal flake normally would require reshooting the whole panel to get it right, but you run the risk of the tint being off unless you get the mix, humidity, gun settings and other variables all the same as when you shot it. Did you keep a record of what you mixed, air pressure used, gun settings and the like?
Give me ambiguity
or give me something else
yes but for such a small slip I would have to hate repainting the whole cab
Cab huh? Bummer. Depending on where it is you could maybe try a blend. Try the brush or airbrush and see if you can live with it...
Give me ambiguity
Always protect stuff when assembling. Tape, cardboard, clean new rags, old sheets.
http://transportwrap.com
I took a chip out on my truck. I wet sanded with 400-600 to take off edge and I dabbed that area with paint only with my finger a couple times and then wet sanded, it blended ok. If you look hard you could see....but was ok by me...depends on your standard
Dan
This is why we paint the edges, put it all together, and then spray the whole truck complete. Sorry to hear you chipped it. You can brush the area, then wetsand it, then when you powerpolish the whole truck it will blend.
My 46 GMC on Photobucket
..perhaps you have a paint store that can put your color formula into a spray can so you can spray it? Just a thought.
Last can I had fixed up was 20 bucks but it makes it nice to do some kinds of touch up.
when i had my 40 painted i was worried about every one scratching it up. NOT its only me that scratching and chipping around here. even with precautions stuff still seems to happen ohwell as a matter of fact i just took it to get some touch up work on it yesterday. big_eek
Had a same problem with my 49 Pickup with metallic paint. First mask off only the chip with tape. Take a VERY small amount of paint using a toothpick or touch-up microbrush and dab the smallest amount of paint on the chip. Wait 3-4 hours and repeat until you build up the paint. This may take a few days. Then with the tape on wet sand with the very fine sand paper. You may have to keep putting tape on. Apply more paint if needed. Do this until you build up the paint. Then remove tape. Do a final wet sand with very fine paper. Finally buff with very fine polish/compound. This could take days. Take your time!
