Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
8 members (Hotrod Lincoln, farmallb, Chip O, tclederman, Charles in CA, Otto Skorzeny, Stovebolt48, TooMany2count), 46 guests, and 0 robots.
Topics128,006
Posts1,055,272
Members48,418
#944156 05/18/2013 9:26 PM
What do you guys make of these numbers ?
engine serial # 0234S4IT56Z
engine casting # 3837004
Head casting # 3835913
We pulled this engine out of a 1955 or 1956 6500 series truck.
Thanks,Tim
1951 3100 Chevrolet
T56Z
1956 passenger car 235
0234S4I = 0234541 ?
T = Tonawanda, NY
56 = 1956
Z = standard engine/transmission
57/58 block casting code
54/55 head casting code
Post the head/block date casting code (the head code, in particular, under the valve cover at the rear manifold-side of the head)
Tim,I'll try to get the numbers posted this evening or tomorrow.
Thanks for your knowledge and help.
Tim
1951 3100 Chevrolet
Tim,the code stamped in the rear under the valve cover is E 55 CON 9.
Tim
1951 3100 Chevrolet
bowtietim #944416 05/19/2013 10:08 PM
Tim,
Wait to hear from someone else, but I'd say that is
E = May
5 = 5th
5 = 1955
I know it has to be the 2nd series 235,it has the large hole for water pump in front of block.
Tim
1951 3100 Chevrolet
Looks like a late 1955 engine 235 that was put in a 1956 car?
All 1956 and later 235 engines had hydraulic lifters. I wonder if the late 1955 car engine put in a 1956 car had mechanical lifters (only Powerglide-equipped 1955 235 car engines had hydraulic lifters).
bowtietim #944673 05/20/2013 10:22 PM
Tim,I will be pulling the side cover to check to what lifters it has.
Thanks,Tim
1951 3100 Chevrolet
