0 members (), 120 guests, and 4 robots.
Topics128,184
Posts1,057,266
Members48,467
Wanted to ask and see if anyone has used an EZ Wiring fuse block kit?
They have the 12 and 21 circuit kits.
If anyone has used them,how simple are they to install?
Thinking of re-wiring my 53 Panlel and was looking for opinions on these kind of kits
Manley
i have used the complete wireing kit in several cars and trucks . it is easy to install the wires are marked every 6"as to where they go. and the instructions are very easy to understand. for the price difference i always buy the 21 circuit. then you can up date later if you want to
I installed the 21 circuit also. When I first saw all the wires, it was like OMG what have I got into now. smile
But, as stated it was an easy install. I did not follow EZ Wiring advice on clipping short at the fuse box wiring I wouldn't use or use later. I removed them just to keep wiring under the dash neater. Other than that I followed their instructions. I would recommend having a good set of wire nipper/crimpers and strippers.
Drew
I used their mini fuse panel and like it. If you use the mini fuse panel just be sure to buy you an extra fuse or two "just in case". Not everyone carries the little mini fuses on the shelf..at least not yet.
I too have used the 12 circuit mini fuse in my 1948 1-ton. Made life so easy for rewiring the whole truck.... I'm going to use another one on my next project. I would recommend them for anyone doing a wiring job.
"IT IS WHAT IT IS"
1953 Chevrolet 1/2-ton 3100 4x4
In the DITY Gallery
More images in Flickr
1948 GMC 1-Ton (now sold to someone in Hawaii!)
More photo in Flickr
1953 Chevy 1-Ton
I used the 21 circuit one in my truck and other than making a couple of small 'adjustments' to conform to European specs (our stop/turn signals are different) the turn signals must be separate,it was a no brainer.
Although i've since found out I could have left it 'as is' on a vehicle this old..... ohwell
Like the guys mention and I'm sure you already know,they're marked every 6".
Just pay attention to getting good grounds (most electrical fault can be traced to bad earthing)
More pix on Flickr.
Thanks for all the info Guys.
I will definitely go with the EZ Wiring.
Manley
Stovebolt Photo Moderator
Manley,
Can you post a link to the EZ wiring fuse block kit that you are referencing? I'm about to restore a 47 one-ton and your idea sounds attractive.
Joe
1947 - 3800 dually known as "Deadwrench"
Link to a few photos
In this world there are givers and takers. The takers eat well, the givers sleep well.
