5 members (dt235sd, klhansen, 2-Ton, 52GMC35424JD, Hotrod Lincoln), 79 guests, and 3 robots.
Topics128,049
Posts1,055,665
#943223 05/14/2013 7:47 PM
hey i am thinking about doing a power booster to my drum brakes ,, i know i should do the kit but i am thinking my budget ,,, can i do a power booster now and maybe do the disc later on ???,, or should i just the booster and leave it alone
go easy on me lol
thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #943236 05/14/2013 8:32 PM
i put a power booster on my friends 38 truck with drum brakes made a world of difference in the way it stops.
lilrobo #943246 05/14/2013 9:24 PM
I need to find out what will work on my 58
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #943248 05/14/2013 9:40 PM
I put power brakes on my '59 3600 with all drums, stops great! No need for disc on mine. It being a 3/4 ton I guess it has bigger drums than a 1/2 ton though.
Darren
lilrobo #943313 05/15/2013 2:13 AM
http://www.ebay.com/itm/Chevy-Truck-Power-Booster-Pedal-Kit-BONUS-Free-Valve-/140973319730?pt=Vintage_Car_Truck_Parts_Accessories&fits=Year%3A1958%7CModel%3ATruck&hash=item20d2aa2632&vxp=mtr
"IT IS WHAT IT IS"
1953 Chevrolet 1/2-ton 3100 4x4
In the DITY Gallery
More images in Flickr
1948 GMC 1-Ton (now sold to someone in Hawaii!)
More photo in Flickr
1953 Chevy 1-Ton
Slick69 #943323 05/15/2013 5:39 AM
Sorry thats for a truck i need one for a biscayne
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #943383 05/15/2013 11:55 AM
Adding the booster will require reworking the brake lines to fit the new location of the master cylinder. If you later want to convert to front disks, a proportioning valve will be required and you will have to rework the brake lines again. I think the duel circuit drum and dual circuit disk/drum master cylinders are physically the same.
lilrobo #943393 05/15/2013 12:20 PM
thats good to here,, now all i need a part number ,, i been looking and hoping that they were the same
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #944000 05/18/2013 6:16 AM
So if i put a power booster on my car with drum front and rear,, do i need a prop valve, , i was told that if i wanted to add disc in the furture i would have to changethe master cyl,, why not add it then? ?. If i go that way, , i say drum drum will be just fine? ?.
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #944121 05/18/2013 6:35 PM
This is for what its worth.
I have drum drum on my 52panel with a dual master cylinder and a booster.
So far I've only put just over 300 miles on it. I do not have a proportioning valve on it now. It stops very well. Just yesterday a young and dumb cell phone talking idiot pulled smack dab out in front of me. I got on the brakes hard and was surprised at how well they worked in an emergency. I like them.
I did put a 10lb residual valve on the rear lines.
I'm sure you'll get differing opinions but this is my story. I'm sure others will have different opinions.
Yes, I'll put a proportioning valve on IF and WHEN I do go disc on the front.....but since the panel is no hot rod I may leave it just like it is.
Since you live in the HILLS of Kentuck smile watch out for the drums. They do heat up and fade faster than any disc.
lilrobo #944354 05/19/2013 5:09 PM
i am getting ready to drop a few bucks on brake stuff , like booster, drums shoes and wheels cyl and and a radiator,, wheres a good cheap place so far auto city classic is the best deal ,, maybe rock auto,, anywhere else i can look??
thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #944424 05/19/2013 10:22 PM
drums, wheel cylinders and such can be obtained from a lot of local parts stores. If not in stock they can be overnighted with no shopping charges.
(can your drums be turned?)
Check SEVERAL places before you spend your money.
lilrobo #944484 05/20/2013 8:03 AM
I got a radiator from Auto City Classic and have been very pleased with it.
lilrobo #944589 05/20/2013 4:50 PM
thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
