2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
#943896 05/17/2013 6:23 PM
My 46 is running and driving good with exception of shifting. Orginally I thought it was operator error, but after a few days of grinding the transmission I've determined it is a tranmission problem. I've also never had problems driving a 52 2ton with the same transmission or a 33 1.5ton. Hopefully the clutch just needs and adjustment. It feels fine pushing on it and it isn't slipping. Shifting up from 1st through 4th is fine. But trying to get it back into 2nd or 1st while (or any other gear) stopped doesn't work. I have to jamb it into gear, with that comes a lovely grinding noise. What is the clutch adjustment process.
I didn't see anything on tech tips.
Jason
1946 GMC COE
1967 Pontiac Lemans Convertible
http://s1275.photobucket.com/user/jrpontiac/library/?sort=3&page=1
Camp Commandant
Camp Commandant
Jason, your post reminded me of when I first got my truck on the road. I thought my tranny was bad but it turned out it was the driver. Not saying you may not have a problem since it sounds like you have experience shifting these transmissions. Anyway, here's my thread from long ago......
https://www.stovebolt.com/ubbthread...amp;Main=4650&Number=29017#Post29017
I did eventually get the hang of it!
~ Billy
1959 GMC 860 | Pictures
Hi,Jrpontiac!! Since it sounds like you're having the most trouble gettin' "her" back in gear at a stop,then it sounds like your clutch is slightly engaged. There should be a threaded rod,connecting your linkage to the clutch-fork. Depending on whether it's "Stock",or not,it may require an over-nite soak with your favorite penetrating fluid. The nut should be 9/16,and mine is double-nutted,to prevent it from loosening on its own. Loosen the outer nut first,just turn it counter-clockwise a couple of grooves,then spin the second nut flush. Make sure the washer,(on the back,-Bell-Housing side of the clutch-fork), isn't frozen to the shaft,otherwise,you won't be able to get it to adjust. There should be a nut on the shaft,on the Bell-Housing side,(Toward engine) of the clutch-fork,as well. Turn that one CLOCKWISE,until it sandwiches the washer between the nuts. Keep adjusting until you're able to shift into gear,without grinding,and make sure clutch doesn't slip,when you engage it. You should end up with about 1/4-1/2" free-play,in your pedal. Hope this helps.
Mo' Tater
