| | | Forums66 Topics128,049 Posts1,055,695 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | hey i am thinking about doing a power booster to my drum brakes ,, i know i should do the kit but i am thinking my budget ,,, can i do a power booster now and maybe do the disc later on ???,, or should i just the booster and leave it alone
go easy on me lol thanks
1958 chevy biscayne 235 6 cyl 1 barrel 2 speed PG tranny
| | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | i put a power booster on my friends 38 truck with drum brakes made a world of difference in the way it stops.
| | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | I need to find out what will work on my 58
| | | | | Joined: Sep 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 166 | I put power brakes on my '59 3600 with all drums, stops great! No need for disc on mine. It being a 3/4 ton I guess it has bigger drums than a 1/2 ton though. Darren | | | | | Joined: Aug 2008 Posts: 290 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 290 | http://www.ebay.com/itm/Chevy-Truck-Power-Booster-Pedal-Kit-BONUS-Free-Valve-/140973319730?pt=Vintage_Car_Truck_Parts_Accessories&fits=Year%3A1958%7CModel%3ATruck&hash=item20d2aa2632&vxp=mtr
| | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | Sorry thats for a truck i need one for a biscayne
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Adding the booster will require reworking the brake lines to fit the new location of the master cylinder. If you later want to convert to front disks, a proportioning valve will be required and you will have to rework the brake lines again. I think the duel circuit drum and dual circuit disk/drum master cylinders are physically the same. | | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | thats good to here,, now all i need a part number ,, i been looking and hoping that they were the same
| | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | So if i put a power booster on my car with drum front and rear,, do i need a prop valve, , i was told that if i wanted to add disc in the furture i would have to changethe master cyl,, why not add it then? ?. If i go that way, , i say drum drum will be just fine? ?.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | This is for what its worth. I have drum drum on my 52panel with a dual master cylinder and a booster. So far I've only put just over 300 miles on it. I do not have a proportioning valve on it now. It stops very well. Just yesterday a young and dumb cell phone talking idiot pulled smack dab out in front of me. I got on the brakes hard and was surprised at how well they worked in an emergency. I like them. I did put a 10lb residual valve on the rear lines. I'm sure you'll get differing opinions but this is my story. I'm sure others will have different opinions. Yes, I'll put a proportioning valve on IF and WHEN I do go disc on the front.....but since the panel is no hot rod I may leave it just like it is. Since you live in the HILLS of Kentuck  watch out for the drums. They do heat up and fade faster than any disc.
| | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | i am getting ready to drop a few bucks on brake stuff , like booster, drums shoes and wheels cyl and and a radiator,, wheres a good cheap place so far auto city classic is the best deal ,, maybe rock auto,, anywhere else i can look??
thanks
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | drums, wheel cylinders and such can be obtained from a lot of local parts stores. If not in stock they can be overnighted with no shopping charges. (can your drums be turned?)
Check SEVERAL places before you spend your money. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I got a radiator from Auto City Classic and have been very pleased with it. | | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 |
