| | | Forums66 Topics128,139 Posts1,056,756 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 135 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 135 | 51 Deluxe, Powerglide 235, 37k miles. Pulled the head to freshen up vaves and seals, pulled the original cast iron pistons out, looking to replace them with aluminum pistons. Cylinder bore is .003 over with less than .005 taper. I called Egge and asked them what they suggest for piston to cylinder wall clearance on their pistons and they told me .0025 to.003. This would put me at.006 piston to cylinder wall clearance with the new pistons. I really don't have the time to yank the engine and do a complete overhaul, so my question is Would ya run it?
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I would put the aluminum pistons in. It may be a little noisy until the pistons warm up but I think you will be happy.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2012 Posts: 135 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 135 | Thanks for the input Dave, I respect your opinion | | | | | Joined: Apr 2012 Posts: 135 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 135 | I would put the aluminum pistons in. It may be a little noisy until the pistons warm up but I think you will be happy. Knurled the pistons to tighten the clearance up. You are right Dave, I'm very happy with the way it runs | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Glad to hear it worked out!
