0 members (), 149 guests, and 2 robots.
Topics128,113
Posts1,056,619
Members48,450
51 Deluxe, Powerglide 235, 37k miles. Pulled the head to freshen up vaves and seals, pulled the original cast iron pistons out, looking to replace them with aluminum pistons. Cylinder bore is .003 over with less than .005 taper. I called Egge and asked them what they suggest for piston to cylinder wall clearance on their pistons and they told me .0025 to.003. This would put me at.006 piston to cylinder wall clearance with the new pistons. I really don't have the time to yank the engine and do a complete overhaul, so my question is Would ya run it?
I would put the aluminum pistons in.
It may be a little noisy until the pistons warm up but I think you will be happy.
My Blog
Thanks for the input Dave, I respect your opinion
Knurled the pistons to tighten the clearance up. You are right Dave, I'm very happy with the way it runs
Glad to hear it worked out!
My Blog
