3 members (ShopRag, 55shaker, Otto Skorzeny), 106 guests, and 0 robots.
Topics128,163
Posts1,056,920
Members48,458
What all is needed to swith over from a 3 speed to a 4speed transmission in my '50 3600 stock truck. The 3peed is connected to the shaft in an enclosed torque tube. The 4 speed that I am looking at does not have the fitting to connect the torque tube cover. Am I missing something on the install or do I need a different intermediate shaft?
john
You may want to look into an open driveline. Perhaps look at a 1 ton or greater 4-spd with the open driveline connection. Then probably a new center carrier and short driveshaft from a driveshaft center. Otherwise, follow my post. There are no readily available parts.
The 4spd will only give you a lower gear. Top gear is still 1:1 or direct.
Not sure, but the bellhousing may be different between the two as well as the clutch size.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
