7 members (Chip O, J Lucas, Hotrod Lincoln, tclederman, Bill Hanlon, 2 invisible), 74 guests, and 2 robots.
Topics128,205
Posts1,057,427
Members48,471
Anyone have any neat ideas for the heater fan control on early AD trucks? Just re-did my whole interior, and now getting to heater, etc. Way back when I started this, I took out that rheostat-type rotary switch-on-a-clamp that you see in catalogs, which most people clamp on the lower edge of the dash. Don't know what was original. Interested in any new or differnet ideas out there.
It would have to use that kind of setup. I had that in my truck. But my whole system was a rusted mess and I tossed it. Perhaps you could mount it on a shaft and put it somewhere in the dash?
Kevin, why don't you go with the stock one. I see them on ebay from time to time, unless you have a 12V system? Cecil.......
yeah, the stock one should be available and would look better than a box ahgning off of the dashboard.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
I've got a 12-volt system, but I'll look around and see if I can find something original. But I'm not sure what "orginal" is.
Likewise...Go Seahawks!!
Ex Hall Monitor
Ex Hall Monitor
I had a '55 1st panel & the red rheostat that mounted under the dash was the original on it according to the fellow I bought it from.
You might want to consider the early 2 speed "toggle type" swiches which control fan speed on the defroster and heater motors.(one swicth each)...has either a black or ivory plastic toggle with either "heat' or defrost" embossed on it. They bolt to the underside of he dash. Golden State sells them and/or they come up on ebay regularly.
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
I
I Offline
The original 6V one should be sufficient to handle the load of the 12V because the amp draw should be 1/2
IRWIPI 2005 Peoples Choice
Inky,
"It's not that I haven't done IT... It's that I haven't done IT yet."
'48 1-1/2 ton Dump
'57 Chevy Panel
'59 Chevy 2 ton Dump
I just put on some more clothing,,,no heater in my 52....................
Redryder pix
My Hotrod
Inky05 is right. The stock switch will work with either 6 or 12 volt. Its the fan motor that has to be 12volt. Cecil........
Some of the switches also say "AIR"
1954 GMC De Luxe COE
Just my opinion, but if you go to an electrical supply house, They probably have a great selection of different reostats, toggles and other choices to make it work, and still fit in your dash where the cigarette lighter used to be, or another hole that you aren't using..
Now, I have to go myself to replace my clamp on switch..
Good luck, Shoop
Thanks everyone. I think I'll look for the 'toggles' mentioned by 'Steveg'. I haven't used Golden State Pickup Parts for about 10 years, when I was getting parts for a '62 GMC I had a while back. Are they still around? And 'Joker': yeah a sweater every now and then works. But after 14 yrs in Vegas and Arizona (thin blood!) I need a heater in my restored '53 here in Washington! Thanks again everyone!
