| | | Forums66 Topics128,047 Posts1,055,532 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94251 01/11/2006 6:33 AM | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | Just purchased a rebuilt Delco Remy 12V genaerator. I'm assuming I can't use my Delco Remy Voltage Regulator because it was paired with an alternator previously. Where can I purchase a Regulator that will go with a 12V generator BUT is period looking in all respects? | | |
#94252 01/11/2006 6:40 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes the alternator regulator should be different - the original style regulator's are still available for the 12V generator - I'm sure all the repro suppliers will have'em, or if you've got an auto elec place around that's got some older techs, or one that works on farm equipment sometimes, ask there - the local guy here has'em on the shelf - NAPA might have'em listed too
Bill | | |
#94253 01/11/2006 6:50 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | I know that American Classic has them.
So does Jim Carter.
Check with your FLAPS. If they don't have them, they can usually get them. | | |
#94254 01/11/2006 3:47 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Local auto parts store. They are going to know the amp output on the generator, so either get the part number off it or take it with you. They should have one on the shelf.
Fred 52 3600 69 C-10
#94255 01/11/2006 5:04 PM | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | According to the Auto Electric shop where I purchased the rebuilt generator, they said it is putting out 50 amps. They ordered a regulator to go with it but the case, though black and the same geometry as the Delco Remy I have had that cheapo no name, yellow-ey looking metal. Had China all over it. I'll check NAPA, Jim Carter and American Classic. THanks guys, -jeff | | |
#94256 01/11/2006 6:10 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Delco-Remy-san Stuart | | |
#94257 01/11/2006 11:18 PM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | A 57 regulator should work fine and looks as close as your going to get. Cecil.......... | | |
#94258 01/12/2006 12:30 AM | Joined: May 2000 Posts: 49 Member | | Member Joined: May 2000 Posts: 49 |
1951 1/2 ton "Buck" Recently lobotomized for your safety.
#94259 01/12/2006 3:25 AM | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | Stuart, The san is Japanese. It implies respect to ones' name. FYI -jeff | | |
#94260 01/12/2006 5:04 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Jeff, gomennasai. Stuart | | |
#94261 01/12/2006 5:02 PM | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | TT, Took your adce and checked out ebay. There's a NOS reg there but the lister can't tell me what it's for. He gives number (the code). Does DElco Remy have a site (link) where I can check those numbers? | | |
#94262 01/12/2006 5:16 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | don't know if they would still have that info, but you could try here Bill | | |
