2 members (IHPWR, Shof), 116 guests, and 2 robots.
Topics128,034
Posts1,055,540
Members48,425
#941796 05/08/2013 4:06 PM
I need to replace all of the old wiring in my 58' Apache. My question is what company(Brothers, LMC)etc. has the best quality? I just need a basic system to replace the old wiring.
Take a look at rebel wiring
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen
56 Chevy 3100
When I wanted to rewire my stock 49 I checked almost everyone's product. Could not find one that was basic. They all seemed to have features like alternator, power window, steering column ignition and so on.
I took a look at the wiring schematic and realized it was actually quite simple. I bought wire, terminals and rewired my truck myself. Simply did one wire at a time. The most difficult part was wiring the dash because of access.
I don't know if a 59 would be more complex than my 49 but I think its worth a try.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Rebel Wire
Classic Parts kits are excellent and match original wiring - original standard circuits, original lengths and color codes, and terminated (except for rear lamps - you terminate to match your frame/bed length).
I've always wired my own for my needs. On my current project, I did buy a new harness for the fuel injected motor. This way I had all new connectors. The rest of the truck I'll do myself.
Sedgewick #941996 05/09/2013 12:34 PM
I'm not sure when you wired yours, but there are a lot of simple kits that have been released in the last year or two for those not needing circuits for accessories. All the major wiring harness vendors have them now.
My 46 GMC on Photobucket
I did mine about 5 years back except for the dash/gauge wiring which I kept putting off because of the difficult access.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
I used classic parts wiring harness for my 55.2 3100. Really wasn't hard to install, after you figured everything out. The instructions were terrible. Better instructions would have made it a lot easier. JMO.
Brian
1955.2 3100 Truck
Riding in the Passing Lane
I do a lot of my own wireing but unless I was going to do a lot of it, a kit/harness would be the best way to go. If you do it right you wil have 3-4 hundred dollars in spools of wire & terms. A made up harness has al the circuits marked. It will save a lot of time.
1972 Chevy c10 Cheyenne Super
