1 members (baldeagle),
68
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 101 | First, a story.
After successfully and uneventfully driving my 58 Panel in and out of the carport for two months, I thought I would get a one day permit for a reliability ride and a refresh of why I bought the thing in the first place. It must have known something was happening, so it started running like a bag of hammers. It felt like spark plug wires (hesitation under load but OK idle.) Replace wires, then no start. Turned out it was now out of gas. Filled, but still ran the same. No accelerator pump squirt so pulled off the carb top and found sludge. Sucked it out with pump but still no squirt. Then, started to run great. Drove out to a friend's place to show off. Column shift linkage fell off and shifter fork went out of alignment. Manually put in third and drove home. Fixed shifter, then ran like crap again. Pulled carb and got rid of more sludge (yes I do have a filter but just small glass. Installing a big one with drain and water trap tonight.) Put it back on and idle no more. Ordered carb kit for Carter YF. So, altogether a disappointing day.
So, now my topic! I know lots of you guys have been doing this for years. Can you help me to build a little tool kit to carry with me? No cherry pickers or 3 ton floor jacks - just something for minor issues. I don't have one of those fancy show trucks that has been worked on in detail for the past 15 years, more of a resurrection from junk status. Here is what I am thinking so far:
Some nitrile gloves 1/2 wrench 9/16 wrench 3/8 drive ratchet with a few sockets small adjustable wrench Slot and Phillips screw drivers Needle nose pliers Vise grips electrical test light small collection of washers small collection of cotter pins short length of mechanics wire
Thanks all!
| | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Hi Ted,
We've all been there...
Your kit list is a good start assuming you've included the minimums for a tire change (jack, tire iron, etc.). Some additional items to consider: Flashlight (w/ magnet or a snake light) Fuses Electrical tape Tire pressure gage Some spare bulbs Jumper cables (if you're running 12V) If you have extra room you could include a small hammer, a file, a socket to fit the spark plugs, and a small wire brush.
Good luck and have fun.
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | Good list! In addition, I carry a small floor jack and short lengths of 2x4 Extra oil Extra antifreeze Small set of socket wrenches Road flares Water Jumper cables Extra light bulbs Spare tuneup parts-- cap, rotor, condensor Spare fuel filter Pliers Shop towels Small funnel Lug wrench
Seems like a lot, but most everything has been needed by me or someone else on a cruise, at least once. | | | | | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | Ted I think you have a good list of basic tools. After working for the school district for 25 years and running a wrecker for a number of years I have learned that no matter how good a road service kit you have you will almost always have everything but you need. Electrical tape and wire will often get you home though. Jim | | | | | Joined: Apr 2013 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 101 | Thanks for the suggestion Bill, Jim and Sparky. I am thinking I should mount a truck box in the panel somewhere for emergency supplies.
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i carry a small 3/8 socket set. i have a mechanics choice tool bag like the old time doctors would carry when making house calls. i have a set of wrenches from 1/4" -3/4", a 12" cresent wrench all some of the things that were mentioned to fill it up plus a set of points and a fuel filter along with a timing light. i have it so if i cant deal with it out there on the road with what i got im needing a hook anyway so no need to clutter up the truck. most of all carry a cell phone. | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | .... I don't have one of those fancy show trucks that has been worked on in detail for the past 15 years, more of a resurrection from junk status.... You are going to need a set of clutch head drivers.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | along with much of the items listed above I keep a walker rebuild kit in the truck for my carter carb. also a ...jack... | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | No tool kit is complete without a roll of quality duct tape. My airframe mechanic cousin calls it 500mph tape (some crazy stories). | | | | | Joined: Apr 2013 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 101 | Hey wait a second Dave, shouldn't every roll of duct tape be accompanied by a can of WD40? | | | | | Joined: Apr 2013 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 101 | Dad50 - after your cross country trip I guess you are qualified! | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | The item I use most often from my tool box is a small tube of hand cleaner. My tool box is a little different, it's an old tractor tool box bolted to the running board.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Nov 2010 Posts: 109 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 109 | I have several of those husky sets in a hard plastic case. They have 1/2 and 3/8 and 1/4 drive in metric and inches. Plus, wrenches, allens and screwdrivers and pliers. About $35-50 bucks everyplace.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I haven't seen mention of -sheet of gasket paper -Permatex #2 for the gastets and pipe threads -spare fan belt -feeler gauges if you'll be on a real long trip and need to adjust valves -Gasket scraper, I made one out of an old broken flat file now about 4" long, ground flat on one side with a bevel on the end for the scraper, and on the top side it is still a file, so can remove nicks and used for the final cleanup of the surface before putting back together.
At one point on a multi-thousand mile road trip I broke a fan blade on the 52, the solution was to cut off the opposite one (for balance) and reinstall the now 2 bladed fan. Sure was glad I packed the hacksaw on that trip!!
Grigg | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | I carry a roll of duct tape to keep my spit cup upright! I went on a cruise with a bunch of like-minded folks when my truck stalled and would not fire. As I discovered several days later, I had an intermittently malfunctioning ballast resistor - no juice to the coil until I hit the right bump in the road. Fortunately one of the guys had a piece of wire with alligator clips on each end so I could jump juice directly from the the hot wire on the starter to the coil and stop obstructing traffic on the Chesapeake Bay Bridge Tunnel on a busy Saturday. Without that prefabricated jumper wire, I would have backed up traffic for miles before I could have rerouted some wires to get Sweet Pea down the road.
| | | | | Joined: Apr 2013 Posts: 19 New Guy | | New Guy Joined: Apr 2013 Posts: 19 | I always carry a tube of that 2 pack putty that sets quickly under water very usefull for repairing any leaks that spring up. Had a fuel pump crack open once and this stuff got me 100 miles home. And a length of fuel hose along with the electrical wire. Rich | | | | | Joined: Apr 2013 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 101 | I will be adding a jumper wire (I just replaced my ballast however.) But I am sure that would be good for a number of test scenarios.
Rich, what is that stuff called? JB Weld? Grigg, I will add some of that - especially the feeler gauges. | | | | | Joined: Apr 2013 Posts: 19 New Guy | | New Guy Joined: Apr 2013 Posts: 19 | [quote=Teds58Panel]I will be adding a jumper wire (I just replaced my ballast however.) But I am sure that would be good for a number of test scenarios.
Rich, what is that stuff called? JB Weld? Grigg, I will add some of that - especially the feeler gauges. [/quote] The stuff I have now is called Everbuild stick 2 but I am in England, sure you have something similar in Home Depot. Probably your most useful tool if you break down is a cellphone, it's the one thing I feel very exposed leaving home without, in an old vehicle. Rich | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | You need a normal tool kit, that includes 1/4 to 3/4 combo wrenches, same with the socket set with deep and shallow sockets. Screwdriver set, allen drivers and or wrenches, plier set with diagonal, needle nose, combo, water pump or channel locks. Stubby screw drivers. As far as supplys to bring, hand cleaner, paper towels, water, extra oil, antifreeze, hose clamps, wire, both electrical and saftey or black wire. Electrical tape, extra bolts, nuts and washers, various sizes. Extra ballast resister, points and condenser, rotor etc. If its a long trip and why I want a pickup, with a canopy, extra tires, airpump, fuel pump, the gasket material is a good idea, as well as gasket sealers. Plastic garbage bags, large plastic tarp, rope and tie straps. Spare radiator, fuel pump, water pump, thermostat. Extra flex brake line, brake fluid, grease for emergency wheel bearing repair, extra wheel bearings. If you have an extra transmission toss it in too. Extra gas, hose etc. I do like to be prepaired. Since no old truck running and driving yet, I carry most of the stuff mentioned before long trip in a small car that is a daily driver. Its also handy to help out others in need on the road too.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Jun 2012 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 60 | At the rate you guys are going it will soon become apparent why we all drive trucks with nice roomy boxes for our tools . Not that I am disagreeing i have been packing tool kits around since I got my first car.
Allan 1946 GMC 1949 Mercury M68
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Hey Truckrolet, Why not just get a car carrier and tow an extra truck, man? Seriously, it is impossible to carry everything you may need, but part of the joy of getting your hands dirty working on every part on these trucks is that this puts us in the position to fix whatever goes wrong. If you don't have exactly what you need to fix it, then you get to "McGiver" it back together, and you'll have a great story to tell.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | some of you guys sound like you're planning on opening a mobile restoration service  I've driven old trucks all my life with the most minimal of tools on board, frequently none, usually without a spare or sometimes without even a jack - at most, on many cross country trips, I've lugged along my old USAF canvas tool bag with it's normal complement of hand tools .... if the truck isn't dependable enuff to leave home, then don't - if you've done a reasonable job of "resurrecting" it but are a worrier, just take along your cell phone  Bill | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I was having issues a few summers ago with flooding. On three seperate occasions it flooded and shut down. Coasted to the side pulled the top of the carb, cleared and was able to get home. One time I was in a pep boys parking lot with my son who was 4 at the time.
Well I learned to keep a small roll of left over jute pad behind the seat. If I work over the hot engine I'll lay it over the rad tank or other areas.
Also if you ever have to change a tire it makes a good knee pad over hot asphalt in summer time. (desert climate) | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | some of you guys sound like you're planning on opening a mobile restoration service  I've driven old trucks all my life with the most minimal of tools on board, frequently none, usually without a spare or sometimes without even a jack - at most, on many cross country trips, I've lugged along my old USAF canvas tool bag with it's normal complement of hand tools .... if the truck isn't dependable enuff to leave home, then don't - if you've done a reasonable job of "resurrecting" it but are a worrier, just take along your cell phone  Bill FINALLY!! Someone said what I've been thinking since this thread started! I agree that it doesn't hurt to take a few things along, especially on a longer trip. But gee whiz, if you're going to take the whole shop along with you, then you may as well just drive the truck around the yard, where the shop is always nearby! | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | On a longer trip, I'd have a brake adjustment tool.
I do have a tow rope in my '48 but the only time I've used it was to tow a '52 Ford back to its home. Boy, did that feel good. I went the long way. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...and I've always said if one can stop and start and make short trips for months on end "around town" then it should be easier to take a trip where the going is constant. As my brother use to say "go or blow"  | | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | I am another one of those guys who was opening my eyes wide open reading this thread!!! I do not have any tool in my '57 Suburban, or in any of my cars, for that matter. My '93 Buick has not had s apare wheel for years! If my wife is with me, I can use her cell phone. And if you are really scared, get a AAA membership, for convenient free tows. Or buy a new car! Tools are dead weight and they make rattling noises all the time, too.
'57 Chevy Suburban; '70 Chevy Impala.
| | | | | Joined: Apr 2013 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 101 | I think the weight of tools people are bringing relates directly to their past experiences and the condition of their trucks. I bought mine about three months ago and almost everything I looked at has been Mickey Moused. I have been spending most of my time on bodywork, and frankly, I have not even had all four wheels off. It would not make sense for me to drive with no tools. Give me few months or so to have things sorted out and I will be carrying a lot less. Bill, You are a brave man to not carry a jack! I didn't last weekend, but that was more lack of planning! And of course it depends on how far and where you are going. I think my long term goal will be confidence to not bring more than a cell phone. But that means I better get off this iPad and out to work again.
